iHome iAVS16 Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
69
All Time:
688
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
The iHome iAVS16 is an Amazon Alexa enabled bedside/office alarm clock capable of setting alarms, telling time and date, as well as playing music and controlling smart devices within the home via voice commands. This guide will show you how to disassemble the iHome iAVS16 bedside clock to access the motherboard in case of failure. Before beginning, make sure to power off the device completely and disconnect from any external power source.
Tools
    1. iHome iAVS16 Motherboard Replacement, Power Board: step 1, image 1 of 3 iHome iAVS16 Motherboard Replacement, Power Board: step 1, image 2 of 3 iHome iAVS16 Motherboard Replacement, Power Board: step 1, image 3 of 3
      • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
      • Lift up the bottom of the device.
      • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
      Ask FixBot
    2. iHome iAVS16 Motherboard Replacement: step 2, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 2, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 2, image 3 of 3
      • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
      • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
      • Lifting too quickly could damage the ribbon cable still attached.
      Ask FixBot
    3. iHome iAVS16 Motherboard Replacement: step 3, image 1 of 2 iHome iAVS16 Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, lift up on the black tab holding the ribbon cable down.
      • Carefully pull the ribbon cable back and out of the slot.
      Ask FixBot
    4. iHome iAVS16 Motherboard Replacement: step 4, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 4, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 4, image 3 of 3
      • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
      • Carefully flip the board over.
      • Remove the red connector from its socket with a pair of tweezers.
      Ask FixBot
    1. iHome iAVS16 Motherboard Replacement, LCD (Display): step 5, image 1 of 3 iHome iAVS16 Motherboard Replacement, LCD (Display): step 5, image 2 of 3 iHome iAVS16 Motherboard Replacement, LCD (Display): step 5, image 3 of 3
      • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
      • Further remove the front casing off from the device manually with your hands.
      Ask FixBot
    2. iHome iAVS16 Motherboard Replacement: step 6, image 1 of 1
      • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
      Ask FixBot
    3. iHome iAVS16 Motherboard Replacement: step 7, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 7, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 7, image 3 of 3
      • Carefully flip the LCD display over to expose the ribbon cable connecting it.
      • Lift the black tab holding the cable down, and carefully put it out of the socket.
      Ask FixBot
    1. iHome iAVS16 Motherboard Replacement, Motherboard: step 8, image 1 of 1
      • Flip up the back of the device encasing the motherboard.
      Ask FixBot
    2. iHome iAVS16 Motherboard Replacement: step 9, image 1 of 3 iHome iAVS16 Motherboard Replacement: step 9, image 2 of 3 iHome iAVS16 Motherboard Replacement: step 9, image 3 of 3
      Buy
      • Using tweezers, unplug the white, red, and blue connectors from the motherboard by pulling each out.
      Ask FixBot
    3. iHome iAVS16 Motherboard Replacement: step 10, image 1 of 1
      • Carefully unplug the ribbon cable, making sure not to rip it.
      Ask FixBot
James Hoye
97 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 69
All Time: 688
