Up to 20% off select tools
iHome iAVS16 LCD (Display) Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
59
All Time:
620
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your iHome iAVS16 isn’t producing the correct display on the screen or is not working at all, this guide will show you step by step how to disassemble the iHome iAVS16 to access and replace the LCD display. If LCD display still does not work after replacement then start looking else where for issues.
    1. iHome iAVS16 LCD (Display) Replacement, Power Board: step 1, image 1 of 3 iHome iAVS16 LCD (Display) Replacement, Power Board: step 1, image 2 of 3 iHome iAVS16 LCD (Display) Replacement, Power Board: step 1, image 3 of 3
      • Remove the four 1.7 mm Phillips #0 screws located on the bottom of the device.
      • Lift up the bottom of the device.
      • Carefully lift the bottom of the device up as to not damage the ribbon cable connecting it.
      Ask FixBot
    2. iHome iAVS16 LCD (Display) Replacement: step 2, image 1 of 3 iHome iAVS16 LCD (Display) Replacement: step 2, image 2 of 3 iHome iAVS16 LCD (Display) Replacement: step 2, image 3 of 3
      • Remove the two 1.7 mm Phillips #0 screws holding the white face place onto the inside of the device's bottom.
      • Using an iFixit opening tool on the side without the black adhesive, carefully lift up the white face plate.
      • Lifting too quickly could damage the ribbon cable still attached.
      Ask FixBot
    3. iHome iAVS16 LCD (Display) Replacement: step 3, image 1 of 2 iHome iAVS16 LCD (Display) Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, lift up on the black tab holding the ribbon cable down.
      • Carefully pull the ribbon cable back and out of the slot.
      Ask FixBot
    4. iHome iAVS16 LCD (Display) Replacement: step 4, image 1 of 3 iHome iAVS16 LCD (Display) Replacement: step 4, image 2 of 3 iHome iAVS16 LCD (Display) Replacement: step 4, image 3 of 3
      • Remove the two 1.7 mm Phillips #0 screws holding the power board in.
      • Carefully flip the board over.
      • Remove the red connector from its socket with a pair of tweezers.
      Ask FixBot
    1. iHome iAVS16 LCD (Display) Replacement, LCD (Display): step 5, image 1 of 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): step 5, image 2 of 3 iHome iAVS16 LCD (Display) Replacement, LCD (Display): step 5, image 3 of 3
      • Insert an iFixit opening tool into the lining on the front casing and pry it apart. Do this for both sides.
      • Further remove the front casing off from the device manually with your hands.
      Ask FixBot
    2. iHome iAVS16 LCD (Display) Replacement: step 6, image 1 of 1
      • Remove the four 1.7 mm Phillips #0 screws holding the LCD onto the front of the device.
      Ask FixBot
    3. iHome iAVS16 LCD (Display) Replacement: step 7, image 1 of 3 iHome iAVS16 LCD (Display) Replacement: step 7, image 2 of 3 iHome iAVS16 LCD (Display) Replacement: step 7, image 3 of 3
      • Carefully flip the LCD display over to expose the ribbon cable connecting it.
      • Lift the black tab holding the cable down, and carefully put it out of the socket.
      Ask FixBot
Author
with
Marco Sousa
293 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 59
All Time: 620
