iHome IH11 Speaker Replacement
  1. iHome IH11 Speaker Replacement, Outer Case: step 1, image 1 of 1
    • Unscrew the two 9.0 mm screws with a Phillips #1 screwdriver.
    • Remove the translucent bottom case.
    Ask FixBot
  2. iHome IH11 Speaker Replacement: step 2, image 1 of 2 iHome IH11 Speaker Replacement: step 2, image 2 of 2
    • Remove the two 9.0mm screws on the back of the iHome with a Phillips #1 screwdriver.
    • Repeat the previous step for the two 9.0mm screws on the bottom.
    • Carefully slide the back cover off. There are wires connected to the back cover.
    Ask FixBot
  3. iHome IH11 Speaker Replacement: step 3, image 1 of 1
    • Remove the two 12.0mm screws holding the speaker to the iHome with a Phillips #1 screwdriver.
    Ask FixBot
  4. iHome IH11 Speaker Replacement: step 4, image 1 of 2 iHome IH11 Speaker Replacement: step 4, image 2 of 2
    • Remove the four 12.0mm screws on the face of the speaker with the Phillips #1 Screwdriver.
    • Carefully lift speaker out of its casing.
    Ask FixBot
  5. iHome IH11 Speaker Replacement: step 5, image 1 of 1
    • Unsolder the two wires that connect to the speaker.
    Ask FixBot
Courtney Steinberg
35 Reputation
3 Guides authored
Cal Poly, Team 14-9, Maness Spring 2013 Member of Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 27
All Time: 565
