iHome IH11 Dock Connector Replacement
  1. iHome IH11 Dock Connector Replacement, Dock Connector: step 1, image 1 of 1
    • Remove the two 9mm screws that hold on the dock connector with a Phillips #1 Screwdriver.
    Ask FixBot
  2. iHome IH11 Dock Connector Replacement: step 2, image 1 of 2 iHome IH11 Dock Connector Replacement: step 2, image 2 of 2
    • Pop the dock connector out of the iHome and gently pull the white plastic plug connected to the dock connector apart.
    • Remove the four 7.0mm screws with a Phillips #1 screwdriver.
    Ask FixBot
  3. iHome IH11 Dock Connector Replacement: step 3, image 1 of 1
    • Remove both of the black plastic pieces. They should easily slide off of the two guide holes in the circuit board.
    • The dock connector should now be exposed. You can now simply put your new dock connector in the old one's place.
    Ask FixBot
3 other people completed this guide.
Nick Knowles
21 Reputation
2 Guides authored
Cal Poly, Team 14-9, Maness Spring 2013 Member of Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Members
5 Guides authored
2 Guide Comments
Where can I buy a replacement dock connector?
A Ross - Reply Share
Likewise, this guide isn't much good if it uses parts that are unavailable.
CJ Shumate - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 2,601
