Up to 20% off select tools
iHome IH11 Control Buttons Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
5
Past 30 Days:
11
All Time:
718
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
This guide will show how to install new control buttons. For help troubleshooting click the link to our troubleshooting page iHome IH11 Troubleshooting.
    1. iHome IH11 Control Buttons Replacement, Outer Case: step 1, image 1 of 1
      • Unscrew the two 9.0 mm screws with the Phillips #1 screwdriver.
      • Remove the translucent bottom case.
      Ask FixBot
    2. iHome IH11 Control Buttons Replacement: step 2, image 1 of 2 iHome IH11 Control Buttons Replacement: step 2, image 2 of 2
      • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
      • Repeat the previous step for the two screws on the bottom.
      Ask FixBot
    3. iHome IH11 Control Buttons Replacement: step 3, image 1 of 1
      • Remove the two 9mm screws from the top of the iHome with a Phillips #1 Screwdriver.
      Ask FixBot
    4. iHome IH11 Control Buttons Replacement: step 4, image 1 of 1
      • Pop the dock connector out of the iHome and gently pull the white plastic plug from the dock connector.
      Ask FixBot
    5. iHome IH11 Control Buttons Replacement: step 5, image 1 of 1
      • Carefully pull apart the device.
      • Remove the four screws that hold the circuit board for the buttons.
      Ask FixBot
    6. iHome IH11 Control Buttons Replacement: step 6, image 1 of 1
      • Desolder the four connections for the broken button.
      • Solder the new button in the place of the old one.
      • For more information about soldering, refer to the soldering device page. Soldering Skills
      Ask FixBot
Author
with
Courtney Steinberg
35 Reputation
3 Guides authored
Cal Poly, Team 14-9, Maness Spring 2013 Member of Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 11
All Time: 718
