iHome IH11 AC Power Adapter Replacement
    1. iHome IH11 AC Power Adapter Replacement, Outer Case: step 1, image 1 of 1
      • Unscrew the two 9.0 mm screws with the Phillips #1.
      • Remove the translucent bottom plastic piece.
      Ask FixBot
    2. iHome IH11 AC Power Adapter Replacement: step 2, image 1 of 2 iHome IH11 AC Power Adapter Replacement: step 2, image 2 of 2
      • Remove the two 9.0mm screws on the back of the iHome with the Phillips #1 screwdriver.
      • Repeat the previous step for the two 9.0mm screws on the bottom.
      • Carefully slide the back cover off. There are wires attached to the back cover.
      Ask FixBot
    3. iHome IH11 AC Power Adapter Replacement: step 3, image 1 of 1
      • Remove the aluminum bracket by loosening the two nuts and removing the 8.0mm bolts with your hand.
      Ask FixBot
    4. iHome IH11 AC Power Adapter Replacement, Motherboard: step 4, image 1 of 2 iHome IH11 AC Power Adapter Replacement, Motherboard: step 4, image 2 of 2
      • Remove the two 12.0mm screws that hold the motherboard with the Phillips #1 screwdriver.
      • Slide the motherboard gently out.
      Ask FixBot
    5. iHome IH11 AC Power Adapter Replacement: step 5, image 1 of 1
      • Remove the two 9.0 mm screws with the Phillips #1 screwdriver, then slide the circuit board for the AC adapter out.
      • Repeat the previous step by removing the two 9.0mm screws with the Phillips #1 screwdriver for the circuit board for the on/off switch.
      Ask FixBot
    6. iHome IH11 AC Power Adapter Replacement: step 6, image 1 of 2 iHome IH11 AC Power Adapter Replacement: step 6, image 2 of 2
      • Unsolder the main connections holding the AC adapter to the circuit board.
      • Solder new adapter in same position with same connections.
      Ask FixBot
2 other people completed this guide.
Nick Knowles
21 Reputation
2 Guides authored
Cal Poly, Team 14-9, Maness Spring 2013 Member of Cal Poly, Team 14-9, Maness Spring 2013
CPSU-MANESS-S13S14G9
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,031
