Up to 20% off select tools
iHealth Edge Band Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
99
All Time:
978
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will show you how to replace the wrist band on the iHealth Edge. You must take the device and remove the elastic band. This will expose the iHealth Edge and you will be able to put the new band on.
    1. iHealth Edge Band Replacement, Band: step 1, image 1 of 1
      • Pull the elastic band away from the device as shown. You will need to use one hand to support the device and pull the elastic band with the other at about a 45 degree angle.
      Ask FixBot
    2. iHealth Edge Band Replacement: step 2, image 1 of 1
      • Pull the elastic band away from the device, you should now have the device with no band as shown.
      Ask FixBot
    3. iHealth Edge Band Replacement: step 3, image 1 of 2 iHealth Edge Band Replacement: step 3, image 2 of 2
      • Place the elastic band into the channel in the side of the device shown in the picture. The band will pull into the channel and lock into place.
      Ask FixBot
    4. iHealth Edge Band Replacement: step 4, image 1 of 1
      • After pulling the band into place the guide is now complete. Your iHealth Edge should be ready for use.
      Ask FixBot
This guide will show you how to replace the arm band.
Author
with
Gabrielle Bettegnies
349 Reputation
3 Guides authored
IUPUI, Team S1-G4, Freund Fall 2017 Member of IUPUI, Team S1-G4, Freund Fall 2017
IUPUI-FREUND-F17S1G4
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 99
All Time: 978
