Up to 20% off select tools
iFixit Screwdriver Grip Replacement
Views: 4.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
42
Past 30 Days:
190
All Time:
4,176
Comments: 2
2 guide comments.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 minute
Difficulty: Very easy
Community-Contributed Guide
Parts
Tools
Introduction
Go to step 1 ↓
This is a guide to repair the original iFixit screwdriver which was included in the 54 Bit Driver Kit. The rubber grip rings wear out over time and this guide sheds some light on how to get a new grip on your old screwdriver.
    1. iFixit Screwdriver Grip Replacement, Grip: step 1, image 1 of 1
      • Your iFixit screwdriver has seen better days. Its been in one to many tight places and its mated with far too many screw faces. Its been a part of so many fixes that it seriously would appreciate some down time.
      • But no, you want to keep using this driver. You want it to weather the next fix. It's just not performing like it used to in its glory days.
      • So what is this anyway? A guide to fix a screwdriver? You bet.
      Ask FixBot
    2. iFixit Screwdriver Grip Replacement: step 2, image 1 of 3 iFixit Screwdriver Grip Replacement: step 2, image 2 of 3 iFixit Screwdriver Grip Replacement: step 2, image 3 of 3
      • If you're an owner of the original iFixit screwdriver included in the 54 Bit Driver Kit, you've probably noticed that the rubber grip rings on the screw driver wear out over time, develop small tears and fall off.
      • Regardless if they wear from over-torquing or the build up of oils from your hands, it's quite frustrating to lose the grip on a prised screwdriver.
      Ask FixBot
    3. iFixit Screwdriver Grip Replacement: step 3, image 1 of 2 iFixit Screwdriver Grip Replacement: step 3, image 2 of 2
      • Here's the solution: throw some o-rings on it.
      • 1/16in thick, 7/16 OD, 5/16 ID work wonders.
      • OD= outside diameter.
      • ID= inside diameter.
      • I picked up a bunch from my local hardware store. They are manufactured by Midwest Fastner. They cost $0.31 USD each.
      Ask FixBot
    4. iFixit Screwdriver Grip Replacement: step 4, image 1 of 1
      • So how do you remove the old grip? Simple, use your fingernails!
      • Otherwise, use toothpicks!
      • Remember the mohs scale? Wood won't carelessly scratch your metal tool!
      Ask FixBot
    5. iFixit Screwdriver Grip Replacement: step 5, image 1 of 2 iFixit Screwdriver Grip Replacement: step 5, image 2 of 2
      • That's it. If your grip's gone, shower your screwdriver in o-rings.
      • Enjoy that new, glistening rubber grip on your screwdriver.
      Ask FixBot
To reassemble your screwdriver, follow these instructions in reverse order.
8 other people completed this guide.
Author
with
Anthony Kouttron
5,764 Reputation
5 Guides authored
2 Guide Comments
Worked like a charm.
Now all I need is to get instructions on how to assemble a replacement 54-bit driver kit case….
Jason Higley - Reply Share
Thanks for publishing the sizes on this. I have rejuvenated my driver grip.
However, like the other poster, the plastic storage case on mine has cracked and I too would want a replacement.
alan - Reply Share
Past 24 Hours: 6
Past 7 Days: 42
Past 30 Days: 190
All Time: 4,176
