iFixit 26 Bit Driver Kit Technique for Removing Bits
    1. iFixit 26 Bit Driver Kit Technique for Removing Bits, iFixit 26 Bit Driver Kit Technique for Removing Bits: step 1, image 1 of 1
      • Note how challenging it is to remove a required bit from the kit. Argh!
      Ask FixBot
    2. iFixit 26 Bit Driver Kit Technique for Removing Bits: step 2, image 1 of 1
      • Find yourself a rubber band...
      Ask FixBot
    3. iFixit 26 Bit Driver Kit Technique for Removing Bits: step 3, image 1 of 1
      • Wrap said band around the bit and viola! easy bit extraction enabled. You might want to keep that handy rubber band with the kit now.
      Ask FixBot
    4. iFixit 26 Bit Driver Kit Technique for Removing Bits: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Alternate, no-rubber-band solution: use the tweezers supplied in the bit driver kit.
      Ask FixBot
50 other people completed this guide.
aaronmiller
1,412 Reputation
1 Guide authored
2 Guide Comments
I want to order the 26 bit driver kit technique for removing bits
clement mEnThChEl - Reply Share
I just use the included bit driver. Once removed, reverse it and I am ready to go!
P.S. Anyone got a guide on how to fix the hinge. Spring is loose and the bit tray is out.
Harold - Reply Share
Past 24 Hours: 6
Past 7 Days: 33
Past 30 Days: 136
All Time: 6,717
