Up to 20% off select tools
iDevices iGrill Probe Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
98
All Time:
1,808
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The probes may need to be replaced if your device is not reading the temperature properly. In this guide you will learn how to replace the connectors.
    1. iDevices iGrill Probe Replacement, Probes: step 1, image 1 of 1
      • Remove the back plastic cover from the device; this should allow you access to the batteries.
      Ask FixBot
    2. iDevices iGrill Probe Replacement: step 2, image 1 of 1
      • Remove the batteries from the device.
      Ask FixBot
    3. iDevices iGrill Probe Replacement: step 3, image 1 of 2 iDevices iGrill Probe Replacement: step 3, image 2 of 2
      • Remove five black 10 mm Phillips #0 screws from the back side of the device.
      • Remove two silver-colored 5 mm screws using a Phillips screwdriver. The screws are located on the left side of the internal cover.
      • Remove the accompanying plastic tabs under the screws.
      • Gently pull off the back cover from the device.
      Ask FixBot
    4. iDevices iGrill Probe Replacement: step 4, image 1 of 3 iDevices iGrill Probe Replacement: step 4, image 2 of 3 iDevices iGrill Probe Replacement: step 4, image 3 of 3
      • If you have not removed the 2 silver-colored screws; you must remove them now.
      • Remove the metal terminals from the battery slot closest you.
      • Pull the remaining metal terminals out of their slots. Position them such that when removing the internal cover they will not be caught.
      • Remove the internal cover.
      Ask FixBot
    5. iDevices iGrill Probe Replacement: step 5, image 1 of 1
      • After the internal plastic case has been removed, you will have access to the probe contacts.
      • You should then insert the probes to check their connection to the probe terminals.
      Ask FixBot
    6. iDevices iGrill Probe Replacement: step 6, image 1 of 1
      Tool used on this step:
      Buy
      • Using a pair of tweezers, bend the probe contacts back in place. The tweezers will touch the probe terminals when inserted.
      Ask FixBot
Author
with
Michelle Nguyen
204 Reputation
2 Guides authored
IUPUI, Team 3-4, Harley Spring 2016 Member of IUPUI, Team 3-4, Harley Spring 2016
IUPUI-HARLEY-S16S3G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 98
All Time: 1,808
