iDeaUSA CT8 Motherboard Replacement
    1. iDeaUSA CT8 Motherboard Replacement, Motherboard: step 1, image 1 of 3 iDeaUSA CT8 Motherboard Replacement, Motherboard: step 1, image 2 of 3 iDeaUSA CT8 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Place the tablet on a flat surface, facing upwards.
      • Starting from the portholes, use the plastic opening tools to remove the back cover of the tablet from the top half.
      • Being cautious of the wire connecting the speaker and the motherboard, place the front and back portion of the tablet close in proximity.
      Ask FixBot
    2. iDeaUSA CT8 Motherboard Replacement: step 2, image 1 of 3 iDeaUSA CT8 Motherboard Replacement: step 2, image 2 of 3 iDeaUSA CT8 Motherboard Replacement: step 2, image 3 of 3
      • Locate the five 3.5 mm black screws on the motherboard.
      • Use the #00 Phillips screwdriver to remove the screws, place them in an appropriate location.
      Ask FixBot
    3. iDeaUSA CT8 Motherboard Replacement: step 3, image 1 of 1
      • Carefully peel off the tape covering the circuit boards and blue ribbons. The tape can be disposed or saved for reuse.
      Ask FixBot
    4. iDeaUSA CT8 Motherboard Replacement: step 4, image 1 of 3 iDeaUSA CT8 Motherboard Replacement: step 4, image 2 of 3 iDeaUSA CT8 Motherboard Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • After removing the tape, two blue ribbon wires can now be accessed. To disconnect, gently lift up the plastic ZIF tabs covering the wires.
      • Upon lifting the tab, the ribbons can now be safely pulled out of their connections.
      • To avoid breaking or damaging the plastic ZIF tabs, it is recommended to use tweezers.
      Ask FixBot
    5. iDeaUSA CT8 Motherboard Replacement: step 5, image 1 of 1
      • Locate the two wires connecting the speaker to the motherboard.
      • Use a soldering iron to desolder the red and black wires from their sockets.
      • Solder the speaker wires back in place during reassembly.
      Ask FixBot
    6. iDeaUSA CT8 Motherboard Replacement: step 6, image 1 of 2 iDeaUSA CT8 Motherboard Replacement: step 6, image 2 of 2
      • Disconnect the wires connecting the battery to the motherboard.
      • Start from the sides and gently wiggle the connection out until it;s loose enough to pull.
      Ask FixBot
    7. iDeaUSA CT8 Motherboard Replacement: step 7, image 1 of 2 iDeaUSA CT8 Motherboard Replacement: step 7, image 2 of 2
      • Pull out and free the motherboard from its position.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 31
All Time: 442
