iDea USA CT702 Digitizer Glass Replacement
  1. iDea USA CT702 Digitizer Glass Replacement, Digitizer Glass: step 1, image 1 of 1
    • Place tablet on the table with screen facing upright.
    • Starting from the portholes, use plastic opening tool to pry in between the front panel and back cover.
    • Follow the opening along the corners and sides until all latches are unclipped.
    • Remove back cover completely and place it outside of the work area.
    Ask FixBot
  2. iDea USA CT702 Digitizer Glass Replacement: step 2, image 1 of 2 iDea USA CT702 Digitizer Glass Replacement: step 2, image 2 of 2
    • Place tablet facing down.
    • Locate the 4mm screws along the perimeter of the motherboard.
    • There should be 4 screws.
    • Use Philips screw driver to unscrew each one, and carefully place screws in a safe place.
    Ask FixBot
  3. iDea USA CT702 Digitizer Glass Replacement: step 3, image 1 of 3 iDea USA CT702 Digitizer Glass Replacement: step 3, image 2 of 3 iDea USA CT702 Digitizer Glass Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • After screws are removed, gently pull up on the ribbon wire connection to release all 3 wires from the motherboard.
    • Safely remove mother board and battery from tablet by using tweezers.
    • Make sure the small ribbon wires are not damaged when removing larger members.
    Ask FixBot
  4. iDea USA CT702 Digitizer Glass Replacement: step 4, image 1 of 1
    • Remove tape from battery pack, and dispose.
    • Be careful not to touch the wire/battery connection correctly, as it could result in injury.
    Ask FixBot
  5. iDea USA CT702 Digitizer Glass Replacement: step 5, image 1 of 3 iDea USA CT702 Digitizer Glass Replacement: step 5, image 2 of 3 iDea USA CT702 Digitizer Glass Replacement: step 5, image 3 of 3
    • After removing the battery pack and motherboard, the touch sensor unit should be visible.
    • Use small Philips screw driver to unscrew all 6 of the 2mm screws.
    • Use fingers and prying tool to remove the touch sensor unit from frame.
    Ask FixBot
  6. iDea USA CT702 Digitizer Glass Replacement: step 6, image 1 of 3 iDea USA CT702 Digitizer Glass Replacement: step 6, image 2 of 3 iDea USA CT702 Digitizer Glass Replacement: step 6, image 3 of 3
    • After the touch sensor is detached, only the plastic screen should remain.
    • Insert new touch sensor plate into the same position, aligning all screw inputs.
    • Insert all six of the 2mm. screws to connect the new touch sensor to the screen frame.
    Ask FixBot
  7. iDea USA CT702 Digitizer Glass Replacement: step 7, image 1 of 1
    • To continue reassembling the tablet, follow the steps in reverse.
    • Be careful when reconnecting battery, use safety goggles and gloves.
    Ask FixBot
  8. iDea USA CT702 Digitizer Glass Replacement: step 8, image 1 of 3 iDea USA CT702 Digitizer Glass Replacement: step 8, image 2 of 3 iDea USA CT702 Digitizer Glass Replacement: step 8, image 3 of 3
    • To reassemble tablet, follow these steps in reverse order.
    Ask FixBot
David Kambich
110 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 18
All Time: 493
