iDea USA CT702 Button Replacement
    1. iDea USA CT702 Button Replacement, Button: step 1, image 1 of 3 iDea USA CT702 Button Replacement, Button: step 1, image 2 of 3 iDea USA CT702 Button Replacement, Button: step 1, image 3 of 3
      • Place the device face up.
      • Use a plastic opening tool to gently pry open the black panel around the portholes.
      Ask FixBot
    2. iDea USA CT702 Button Replacement: step 2, image 1 of 3 iDea USA CT702 Button Replacement: step 2, image 2 of 3 iDea USA CT702 Button Replacement: step 2, image 3 of 3
      • Pry the rest of the back off; slowly apply pressure from each side to break each clip connection.
      Ask FixBot
    3. iDea USA CT702 Button Replacement: step 3, image 1 of 2 iDea USA CT702 Button Replacement: step 3, image 2 of 2
      • With a plastic spudger tool, pry the keys away from the black key mat to remove them.
      • It is easiest to start with the volume up button key and then work on freeing the next two.
      Ask FixBot
    4. iDea USA CT702 Button Replacement: step 4, image 1 of 2 iDea USA CT702 Button Replacement: step 4, image 2 of 2
      • Replace the button keys, starting with the outer and ending with the innermost key.
      • The back of each button key has a notch that matches an indent on the black button mat. Match the notches and the indents to properly align the buttons.
      • To replace the back cover, follow the first three steps in reverse order.
      Ask FixBot
Daniel Brandt
201 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 86
All Time: 519
