iBook G4 12" 1.33 GHz Keyboard Replacement
  1. iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: step 1, image 1 of 2 iBook G4 12" 1.33 GHz Keyboard Replacement, Battery: step 1, image 2 of 2
    • Lay your iBook upside down on a flat surface.
    • Use a coin to rotate the battery locking screw 90 degrees clockwise.
    • Lift the battery out of the computer.
  2. iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: step 2, image 1 of 2 iBook G4 12" 1.33 GHz Keyboard Replacement, Keyboard: step 2, image 2 of 2
    • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
    • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
    • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
  3. iBook G4 12" 1.33 GHz Keyboard Replacement: step 3, image 1 of 1
    • Remove the four silver Phillips screws that secure the RAM shield.
  4. iBook G4 12" 1.33 GHz Keyboard Replacement: step 4, image 1 of 1
    • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
    • Make sure that you reconnect the keyboard cable before replacing the RAM shield.
10 other people completed this guide.
Attached Documents
1 Guide Comment
The screw is stripped. What should I do?
TheYootz Media Group - Reply Share
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 10,683
