iBook G3 Clamshell LCD Bezel Replacement
    1. iBook G3 Clamshell LCD Bezel Replacement, Battery Cover: step 1, image 1 of 1
      • Use a coin to unscrew the battery cover, and remove battery.
      Ask FixBot
    2. iBook G3 Clamshell LCD Bezel Replacement, Back Cover: step 2, image 1 of 2 iBook G3 Clamshell LCD Bezel Replacement, Back Cover: step 2, image 2 of 2
      • Use a t8 Torx driver to unscrew the two screws holding in the back cover, then remove the cover.
      Ask FixBot
    3. iBook G3 Clamshell LCD Bezel Replacement: step 3, image 1 of 1
      • Open the screen, and remove the two t8 Torx screws holding the bezel in place.
      Ask FixBot
    4. iBook G3 Clamshell LCD Bezel Replacement: step 4, image 1 of 2 iBook G3 Clamshell LCD Bezel Replacement: step 4, image 2 of 2
      • Use a flat tip screw driver to unsnap the bezel from its place.
      • When at the top rubberized area, pry the bezel down.
      Ask FixBot
aidan
101 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 68
All Time: 4,498
