iBook G3 Clamshell Airport Card Replacement
Views: 23K
View statistics:
Past 24 Hours:
3
Past 7 Days:
24
Past 30 Days:
119
All Time:
22,948
Comments: 1
1 comment on steps.
Completed: 18
18 people have marked this guide "completed." Will you be next?
Favorites: 8
8 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 15 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Install an original Airport 802.11b card internally.
Parts
Tools
    1. iBook G3 Clamshell Airport Card Replacement, Battery: step 1, image 1 of 1
      • Use a coin to turn both battery locking screws 90 degrees to the left.
      • Remove the battery cover.
      • Remove the battery from the computer by pulling up on the plastic tab.
      Ask FixBot
    1. iBook G3 Clamshell Airport Card Replacement, Airport Card: step 2, image 1 of 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free. Note that the keyboard ribbon is still attached to the logic board, so you cannot completely remove the keyboard yet.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw (between F4 and F5 key) 180 degrees in either direction and try again.
      • Rotate the keyboard away from the screen and rest it face-down on the trackpad area.
      Ask FixBot
    2. iBook G3 Clamshell Airport Card Replacement: step 3, image 1 of 1
      • If your computer does not have an airport card, you can skip the next two steps.
      • Grasp the clear plastic tab on the airport card and pull up and toward the display.
      Ask FixBot
    3. iBook G3 Clamshell Airport Card Replacement: step 4, image 1 of 1
      • Hold the airport card in one hand and use your other hand to remove the antenna cable.
      Ask FixBot
18 other people completed this guide.
Attached Documents
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 24
Past 30 Days: 119
All Time: 22,948
