iBook G3 14" Lower Case Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
97
All Time:
5,118
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Introduction
Go to step 1 ↓
Replacing the plastic bottom case.
Parts
Tools
    1. iBook G3 14" Lower Case Replacement, Battery: step 1, image 1 of 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Ask FixBot
    1. iBook G3 14" Lower Case Replacement, Lower Case: step 2, image 1 of 1
      • Use a pin to remove the three rubber feet from the lower case.
      Ask FixBot
    2. iBook G3 14" Lower Case Replacement: step 3, image 1 of 1
      • Remove the three newly-revealed Phillips screws.
      Ask FixBot
    3. iBook G3 14" Lower Case Replacement: step 4, image 1 of 1
      • Use a spudger or small flathead screwdriver to pry up the three metal rings that housed the rubber bumpers.
      Ask FixBot
    4. iBook G3 14" Lower Case Replacement: step 5, image 1 of 1
      • Remove the three hex screws using a T8 Torx screwdriver.
      • The screw in the center is shorter than the other two.
      Ask FixBot
    5. iBook G3 14" Lower Case Replacement: step 6, image 1 of 1
      • Remove the two Phillips screws on either side of the battery contacts.
      Ask FixBot
    6. iBook G3 14" Lower Case Replacement: step 7, image 1 of 1
      • Breathe deeply. Trying times are ahead, but we promise the lower case does come off.
      • Push the thin rims of the lower case surrounding the battery compartment in, bending them past the tabs, and then lift up to free that corner of the lower case.
      Ask FixBot
    7. iBook G3 14" Lower Case Replacement: step 8, image 1 of 1
      • There is a slot on the wall of the battery compartment that locks the lower case in place.
      • Use a small flathead screwdriver to pry out the slot's lower rim and pull up on the lower case to free the slot from the tabs holding it.
      Ask FixBot
    8. iBook G3 14" Lower Case Replacement: step 9, image 1 of 1
      • Run a spudger along the seam between the lower case and upper case on the front of the computer to free the tabs locking the lower case.
      • Pull up on the lower case and continue to use the spudger as necessary until you hear three distinct clicks.
      Ask FixBot
    9. iBook G3 14" Lower Case Replacement: step 10, image 1 of 1
      • Continue to run the spudger around the front, right corner.
      • There are two tabs on the port side of the computer, one near the front corner and one near the sound out port.
      Ask FixBot
    10. iBook G3 14" Lower Case Replacement: step 11, image 1 of 1
      • Once the front and sides of the lower case are free, turn the computer so that the back is facing you.
      • Pull the lower case up and toward you until the back tabs pop free.
      • It may be helpful to jiggle the case up and down.
      Ask FixBot
    11. iBook G3 14" Lower Case Replacement: step 12, image 1 of 1
      • Remove the small greasy springs with white plastic caps from either side of the battery contacts.
      Ask FixBot
2 other people completed this guide.
Attached Documents
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 97
All Time: 5,118
