Up to 20% off select tools
iBook G3 14" LCD Replacement
Views: 3.5K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
89
All Time:
3,524
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Parts
Tools
Introduction
Go to step 1 ↓
Replace a broken LCD rather than the entire display assembly.
    1. iBook G3 14" LCD Replacement, Battery: step 1, image 1 of 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Ask FixBot
    1. iBook G3 14" LCD Replacement, Rear Display Bezel: step 2, image 1 of 2 iBook G3 14" LCD Replacement, Rear Display Bezel: step 2, image 2 of 2
      • Use a 1.5 mm hex screwdriver to remove the two hex screws on either side of the display (four screws total).
      • If you don't have a 1.5 mm hex driver, you can probably get these screws out with a T6 Torx screwdriver. However, if you use a T6 Torx driver you'll be more likely to strip the screws.
      Ask FixBot
    2. iBook G3 14" LCD Replacement: step 3, image 1 of 2 iBook G3 14" LCD Replacement: step 3, image 2 of 2
      • Insert the flat end of a spudger perpendicular to the face of the display into the gap between the front and rear bezels near the upper left corner of the display.
      • Rotate the spudger away from the display to pry the rear bezel off the front bezel.
      Ask FixBot
    3. iBook G3 14" LCD Replacement: step 4, image 1 of 1
      • Run your spudger along the top edge of the front display bezel to evenly separate the two bezels.
      Ask FixBot
    4. iBook G3 14" LCD Replacement: step 5, image 1 of 2 iBook G3 14" LCD Replacement: step 5, image 2 of 2
      • Working down from the upper left corner, use the flat end of a spudger to pry the rear bezel away from the left edge of the display.
      Ask FixBot
    5. iBook G3 14" LCD Replacement: step 6, image 1 of 1
      • Use the flat end of a spudger to pry the rear bezel away from the right edge of the display.
      • If necessary, pry along the bottom edge of the rear bezel to separate it from the display assembly.
      Ask FixBot
    6. iBook G3 14" LCD Replacement: step 7, image 1 of 1
      • Lift the rear bezel off the display assembly.
      Ask FixBot
    1. iBook G3 14" LCD Replacement, LCD: step 8, image 1 of 2 iBook G3 14" LCD Replacement, LCD: step 8, image 2 of 2
      • Close the display.
      • Remove the several pieces of tape securing the thin metal LCD cover to the display.
      • Carefully remove the piece of foil tape covering the display data cable connection.
      Ask FixBot
    2. iBook G3 14" LCD Replacement: step 9, image 1 of 2 iBook G3 14" LCD Replacement: step 9, image 2 of 2
      • Remove the Phillips screw near the right display hinge.
      • Use the tip of a spudger to remove the small spacer under the screw you just removed.
      Ask FixBot
    3. iBook G3 14" LCD Replacement: step 10, image 1 of 1
      • Pull the foil/braided pieces of tape off the aluminum frame of the clutch hinges.
      • Leave the tape attached to the thin steel LCD cover.
      Ask FixBot
    4. iBook G3 14" LCD Replacement: step 11, image 1 of 2 iBook G3 14" LCD Replacement: step 11, image 2 of 2
      • Remove the two Phillips screws securing the left and right sides of the LCD to the frame of the clutch hinges (four screws total).
      Ask FixBot
    5. iBook G3 14" LCD Replacement: step 12, image 1 of 1
      • Carefully remove the thin steel LCD cover.
      Ask FixBot
    6. iBook G3 14" LCD Replacement: step 13, image 1 of 1
      • Disconnect the display data cable by pulling the cable away from the socket on the LCD.
      Ask FixBot
    7. iBook G3 14" LCD Replacement: step 14, image 1 of 1
      • Remove the strip of yellow tape securing the display data cable to the metal LCD frame.
      Ask FixBot
    8. iBook G3 14" LCD Replacement: step 15, image 1 of 2 iBook G3 14" LCD Replacement: step 15, image 2 of 2
      • Disconnect the backlight cable from the inverter.
      • It is helpful to use a spudger to push the backlight connector away from its socket while you lightly pull its cables away from the inverter.
      Ask FixBot
    9. iBook G3 14" LCD Replacement: step 16, image 1 of 1
      • Lift the LCD out of the display assembly.
      • It may be helpful to press the latch release button and open your display slightly to push the LCD out of the display assembly.
      Ask FixBot
2 other people completed this guide.
Author
with
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 89
All Time: 3,524
