iBook G3 14" Airport Card Replacement
Views: 8.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
91
All Time:
8,809
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Introduction
Go to step 1 ↓
Install an original Airport 802.11b card internally.
Parts
Tools
    1. iBook G3 14" Airport Card Replacement, Battery: step 1, image 1 of 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Ask FixBot
    1. iBook G3 14" Airport Card Replacement, Airport Card: step 2, image 1 of 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      Ask FixBot
    2. iBook G3 14" Airport Card Replacement: step 3, image 1 of 1
      • If your computer does not have an Airport card installed, skip to the RAM shield removal step.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      Ask FixBot
    3. iBook G3 14" Airport Card Replacement: step 4, image 1 of 1
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      Ask FixBot
    4. iBook G3 14" Airport Card Replacement: step 5, image 1 of 1
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      Ask FixBot
3 other people completed this guide.
Attached Documents
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 91
All Time: 8,809
