Up to 20% off select tools
iBook G3 12" RAM Replacement
Views: 35K
View statistics:
Past 24 Hours:
3
Past 7 Days:
21
Past 30 Days:
116
All Time:
35,125
Comments: 3
3 comments on steps.
Completed: 47
47 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
One RAM slot will accept PC100 or PC133 chips up to 512 MB.
    1. iBook G3 12" RAM Replacement, Battery: step 1, image 1 of 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Ask FixBot
    1. iBook G3 12" RAM Replacement, Keyboard: step 2, image 1 of 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      Ask FixBot
    2. iBook G3 12" RAM Replacement: step 3, image 1 of 1
      • If the computer does not have an Airport card installed, skip the next two steps.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      Ask FixBot
    3. iBook G3 12" RAM Replacement: step 4, image 1 of 1
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      Ask FixBot
    4. iBook G3 12" RAM Replacement: step 5, image 1 of 1
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      Ask FixBot
    5. iBook G3 12" RAM Replacement: step 6, image 1 of 1
      • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
      Ask FixBot
    6. iBook G3 12" RAM Replacement: step 7, image 1 of 1
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      Ask FixBot
    7. iBook G3 12" RAM Replacement: step 8, image 1 of 1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      Ask FixBot
    1. iBook G3 12" RAM Replacement, RAM: step 9, image 1 of 1
      • Your laptop should look approximately like this.
      Ask FixBot
    2. iBook G3 12" RAM Replacement: step 10, image 1 of 1
      • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
      • Pull the chip directly out from its connectors.
      Ask FixBot
47 other people completed this guide.
Attached Documents
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 116
All Time: 35,125
