Up to 20% off select tools
iBook G3 12" Keyboard Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
102
All Time:
11,844
Comments: 3
3 comments on steps.
Completed: 17
17 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
Replacing this keyboard is easy and takes only a few minutes.
    1. iBook G3 12" Keyboard Replacement, Battery: step 1, image 1 of 1
      • Use a coin to rotate the battery locking screw 90 degrees clockwise.
      • Lift the battery out of the computer.
      Ask FixBot
    1. iBook G3 12" Keyboard Replacement, Keyboard: step 2, image 1 of 1
      • Pull the keyboard release tabs toward you and lift up on the keyboard until it pops free.
      • If the keyboard does not come free, use a small flathead screwdriver to turn the keyboard locking screw 180 degrees in either direction and try again.
      • Flip the keyboard over, away from the screen, and rest it face-down on the trackpad area.
      Ask FixBot
    2. iBook G3 12" Keyboard Replacement: step 3, image 1 of 1
      • If the computer does not have an Airport card installed, skip the next two steps.
      • Push the wire clasp toward the Airport card and pull it up to free it from the RAM shield.
      Ask FixBot
    3. iBook G3 12" Keyboard Replacement: step 4, image 1 of 1
      • Grasp the clear plastic tab on the Airport card and pull toward the right.
      Ask FixBot
    4. iBook G3 12" Keyboard Replacement: step 5, image 1 of 1
      • Hold the Airport card in one hand and use your other hand to remove the antenna cable.
      Ask FixBot
    5. iBook G3 12" Keyboard Replacement: step 6, image 1 of 1
      • Remove the two 2.5 mm Phillips screws that secure the RAM shield.
      Ask FixBot
    6. iBook G3 12" Keyboard Replacement: step 7, image 1 of 1
      • Grasp the metal bracket on top of the RAM shield and pull upward to remove the shield.
      Ask FixBot
    7. iBook G3 12" Keyboard Replacement: step 8, image 1 of 1
      • Pull the keyboard cable up from the logic board, holding the cable as close to the connector as possible.
      Ask FixBot
17 other people completed this guide.
Attached Documents
Author
with
iRobot
1 Reputation
632 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 102
All Time: 11,844
