Up to 20% off select tools
iBUYPOWER Y40 IBP Thermal Paste Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
93
All Time:
381
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
This guide shows how to replace the thermal paste on an iBUYPOWER Y40 IBP gaming desktop. Replacing thermal paste helps improve CPU cooling and prevents overheating during use.
Before you begin the repair, ensure the computer is completely powered off, unplugged, and cooled down.
This guide is intended for beginners and requires only basic tools. Following these steps carefully will help ensure proper heat transfer and maintain system performance.
    1. iBUYPOWER Y40 IBP Thermal Paste Replacement, Thermal Paste: step 1, image 1 of 1
      • Shut down the computer completely and unplug the power cable before opening the case.
      • Allow the system to cool for several minutes before you begin the repair.
      • Never work inside the computer while it is still connected to power.
      Ask FixBot
    2. iBUYPOWER Y40 IBP Thermal Paste Replacement: step 2, image 1 of 3 iBUYPOWER Y40 IBP Thermal Paste Replacement: step 2, image 2 of 3 iBUYPOWER Y40 IBP Thermal Paste Replacement: step 2, image 3 of 3
      • Carefully remove the tempered glass side panel to access the internal components of the desktop.
      • Place the panel somewhere safe to avoid scratches or damage.
      • Handle the glass panel carefully to prevent breakage or scratches.
      • Identify the CPU cooler mounted on top of the processor. It must be removed to access the processor and replace the thermal paste.
      • In this system, a liquid CPU cooler is installed with a pump block connected to the radiator.
      Ask FixBot
    3. iBUYPOWER Y40 IBP Thermal Paste Replacement: step 3, image 1 of 1
      • Use a Phillips #0 screwdriver to loosen the CPU cooler screws in a cross pattern, loosening each screw gradually to avoid uneven pressure.
      Ask FixBot
    4. iBUYPOWER Y40 IBP Thermal Paste Replacement: step 4, image 1 of 1
      • Gently lift the CPU cooler straight out from the processor.
      • If it feels stuck, slightly twist it to break the seal of the old thermal paste before lifting.
      • Do not touch the surface of the CPU with your fingers, as oils from your skin can affect performance.
      Ask FixBot
    5. iBUYPOWER Y40 IBP Thermal Paste Replacement: step 5, image 1 of 1
      • Apply a small amount of 90% isopropyl alcohol to a microfiber cloth and gently wipe the old thermal paste from both the CPU and the bottom of the cooler.
      • Continue cleaning until both surfaces are completely clean and dry.
      • Apply a pea-sized amount of new thermal paste to the center of the CPU.
      Ask FixBot
    6. iBUYPOWER Y40 IBP Thermal Paste Replacement: step 6, image 1 of 1
      • Place the CPU cooler back over the processor and align it with the mounting holes.
      • Tighten the screws evenly to secure the CPU cooler in place.
      • Check that the CPU cooler is properly seated and all screws are tightened securely.
      Ask FixBot
    7. iBUYPOWER Y40 IBP Thermal Paste Replacement: step 7, image 1 of 1
      • Reconnect the power cable, close the case, and power on the system.
      Ask FixBot
To reassemble your device, follow these steps in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Jaylen Emanuel
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 93
All Time: 381
