Up to 20% off select tools
headphone jack Replacement
Views: 2.2K
View statistics:
Past 24 Hours:
0
Past 7 Days:
15
Past 30 Days:
93
All Time:
2,235
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
    1. headphone jack Replacement, headphone jack: step 1, image 1 of 1
      • Turn the phone off.
      Ask FixBot
    2. headphone jack Replacement: step 2, image 1 of 1
      • Remove the back panel with an opener tool.
      Ask FixBot
    3. headphone jack Replacement: step 3, image 1 of 1
      • Lift out the battery using an opener tool.
      Ask FixBot
    4. headphone jack Replacement: step 4, image 1 of 1
      • Remove the SIM and SD card.
      Ask FixBot
    5. headphone jack Replacement: step 5, image 1 of 1
      • Remove the 10 4 mm Phillips screws on the back of the phone using the #00 Phillips screwdriver.
      Ask FixBot
    6. headphone jack Replacement: step 6, image 1 of 1
      • Starting at the USB jack, slide the opener around the perimeter of the phone between the rear case and the frame. This will loosen the clips.
      Ask FixBot
    7. headphone jack Replacement: step 7, image 1 of 1
      • Carefully remove the back case and middle frame and expose the inside of the phone.
      Ask FixBot
    8. headphone jack Replacement: step 8, image 1 of 1
      • Disconnect the foil cable.
      Ask FixBot
    9. headphone jack Replacement: step 9, image 1 of 1
      • Lift the corner of the board and remove the audio jack.
      Ask FixBot
Work the steps in the reverse order to assemble your device again.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Author
with
Peter Hübner
409 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 93
All Time: 2,235
