This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
hard drive replacement (2.5-inch SATA)
View statistics:
Past 24 Hours:
5
Past 7 Days:
32
Past 30 Days:
91
All Time:
735
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide shows you how to replace the 2.5-inch SATA hard drive in an HP 15-db0027nf laptop.
Parts
Tools
    1. hard drive replacement (2.5-inch SATA), Bottom case: step 1, image 1 of 2 hard drive replacement (2.5-inch SATA), Bottom case: step 1, image 2 of 2
      • Remove the feet with a spudger.
      Ask FixBot
    2. hard drive replacement (2.5-inch SATA): step 2, image 1 of 2 hard drive replacement (2.5-inch SATA): step 2, image 2 of 2
      • Remove the 11 Phillips screws using a PH0 screwdriver.
      • The screws are identical.
      Ask FixBot
    3. hard drive replacement (2.5-inch SATA): step 3, image 1 of 2 hard drive replacement (2.5-inch SATA): step 3, image 2 of 2
      • Insert a spudger between the bottom of the frame and the keyboard plate, and go around the computer to unclip the computer cover.
      • Remove the bottom cover from the computer.
      Ask FixBot
    4. hard drive replacement (2.5-inch SATA): step 4, image 1 of 1
      • You now have access to the inside of the machine.
      Ask FixBot
    1. hard drive replacement (2.5-inch SATA), hard drive: step 5, image 1 of 2 hard drive replacement (2.5-inch SATA), hard drive: step 5, image 2 of 2
      • remove the metal piece holding the hard drive in place
      Ask FixBot
    2. hard drive replacement (2.5-inch SATA): step 6, image 1 of 2 hard drive replacement (2.5-inch SATA): step 6, image 2 of 2
      • slide the hard drive to the left to remove it from the connector
      • it may be necessary to slightly lift the back of the hard drive
      • you can then remove it completely from the computer
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
redratchet21 is helping us fix the world! Want to contribute?
Start translating ›
Léo FRAYSSE
1,455 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 32
Past 30 Days: 91
All Time: 735
