Up to 20% off select tools
eufy Security SpaceView Monitor Screen Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
2
Past 7 Days:
11
Past 30 Days:
84
All Time:
3,682
Comments: 2
2 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
One of the bigger items on the list to repair is the screen. This display takes up much of the real estate of the monitor and thus is important to have in good working order. Fortunately, it is a straightforward repair, involving only the use of a screwdriver, to separate and replace the screen from its housing.
    1. eufy Security SpaceView Monitor Screen Replacement, Display Assembly: step 1, image 1 of 2 eufy Security SpaceView Monitor Screen Replacement, Display Assembly: step 1, image 2 of 2
      • Use an opening tool to press into the opening notches built into the lower portion of the display.
      • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
      • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
      • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
      Ask FixBot
    2. eufy Security SpaceView Monitor Screen Replacement, Lift the display: step 2, image 1 of 1
      • Lift the display up and away from the housing.
      • Take care to not twist or pull on the ribbon connector.
      Ask FixBot
    1. eufy Security SpaceView Monitor Screen Replacement, Screen: step 3, image 1 of 1
      • Lay the display face down on a table, to expose the back of the screen.
      • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
      • There are two on each end of the display, and one on each of its longer sides.
      Ask FixBot
    2. eufy Security SpaceView Monitor Screen Replacement: step 4, image 1 of 2 eufy Security SpaceView Monitor Screen Replacement: step 4, image 2 of 2
      • Gently lift the display housing, and set it aside.
      • The housing is ready to have the new display installed.
      Ask FixBot
    3. eufy Security SpaceView Monitor Screen Replacement: step 5, image 1 of 1
      • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
      Ask FixBot
Author
with
ZFarley
443 Reputation
3 Guides authored
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Members
72 Guides authored
2 Guide Comments
Where do you get the replacement screen?
Ronald - Reply Share
Yes please, where do we get a replacement screen, does it come with a ribbon cable? What is the part number?
Laguna - Reply Share
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 84
All Time: 3,682
