Up to 20% off select tools
eufy Security SpaceView Monitor Display Assembly
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
84
All Time:
1,599
Comments: 2
2 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
The preliminary step in any eufy Security SpaceView Monitor repair is disassembling the screen from its housing. As the monitor is one singular unit, the housing, and screen encase its electronic components and thus exist as a prerequisite for further repairs. Fortunately, like many devices like phone cases, the screen has latches built in, and are well designed to pop open for easy removal, via the use of tools suggested in this guide.
    1. eufy Security SpaceView Monitor Display Assembly, Display Assembly: step 1, image 1 of 2 eufy Security SpaceView Monitor Display Assembly, Display Assembly: step 1, image 2 of 2
      • Use an opening tool to press into the opening notches built into the lower portion of the display.
      • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
      • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
      • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
      Ask FixBot
    2. eufy Security SpaceView Monitor Display Assembly, Lift the display: step 2, image 1 of 1
      • Lift the display up and away from the housing.
      • Take care to not twist or pull on the ribbon connector.
      Ask FixBot
To reassemble, lay the display in its original orientation on top of the housing, and apply even force to the edges of the display. It should click each time, and securely itself tightly to the housing.
2 other people completed this guide.
Author
with
ZFarley
443 Reputation
3 Guides authored
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Members
72 Guides authored
2 Guide Comments
I need a new ribbon connector. How do I fix?
Karen Bottai - Reply Share
I need a new display. Does anyone know where I can find it?
Fabio Lago - Reply Share
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 84
All Time: 1,599
