eufy Security SpaceView Monitor Battery Replacement
    1. eufy Security SpaceView Monitor Battery Replacement, Display Assembly: step 1, image 1 of 2 eufy Security SpaceView Monitor Battery Replacement, Display Assembly: step 1, image 2 of 2
      • Use an opening tool to press into the opening notches built into the lower portion of the display.
      • The sides of the display each have two notches, while the top has 3 notches, and the bottom has 4 respectively.
      • Using the given tools, ensure that the tool enters the space of the opening notches, and apply force downwards, prying that specific part up and away from the housing.
      • Repeat for all sides and notches, until the display is completely detached from the rest of the monitor.
      Ask FixBot
    2. eufy Security SpaceView Monitor Battery Replacement, Lift the display: step 2, image 1 of 1
      • Lift the display up and away from the housing.
      • Take care to not twist or pull on the ribbon connector.
      Ask FixBot
    1. eufy Security SpaceView Monitor Battery Replacement, Screen: step 3, image 1 of 1
      • Lay the display face down on a table, to expose the back of the screen.
      • Use Phillips #00 screwdriver to unscrew each of the six screws that hold the display in place.
      • There are two on each end of the display, and one on each of its longer sides.
      Ask FixBot
    2. eufy Security SpaceView Monitor Battery Replacement: step 4, image 1 of 2 eufy Security SpaceView Monitor Battery Replacement: step 4, image 2 of 2
      • Gently lift the display housing, and set it aside.
      • The housing is ready to have the new display installed.
      Ask FixBot
    3. eufy Security SpaceView Monitor Battery Replacement: step 5, image 1 of 1
      • Gently disconnect the ribbon connector from the motherboard, taking care not to damage it.
      Ask FixBot
    1. eufy Security SpaceView Monitor Battery Replacement, Motherboard: step 6, image 1 of 2 eufy Security SpaceView Monitor Battery Replacement, Motherboard: step 6, image 2 of 2
      • Using a Phillips #00 screwdriver, unscrew the 4 retaining screws in each corner of the motherboard.
      Ask FixBot
    2. eufy Security SpaceView Monitor Battery Replacement: step 7, image 1 of 3 eufy Security SpaceView Monitor Battery Replacement: step 7, image 2 of 3 eufy Security SpaceView Monitor Battery Replacement: step 7, image 3 of 3
      • Starting with either red/black wired connector on, gently pull it from its receptor and set it aside.
      • Pull the white ribbon connector from the motherboard, on the side closest to the battery.
      • Lift the motherboard and disconnect the antenna connector from its port.
      • The motherboard is free from the housing and can be replaced.
      Ask FixBot
    1. eufy Security SpaceView Monitor Battery Replacement, Battery: step 8, image 1 of 1
      • Using a Jimmy, place the tool behind the battery where the glue is visible.
      Ask FixBot
    2. eufy Security SpaceView Monitor Battery Replacement: step 9, image 1 of 1
      • Pry the battery from the monitor case.
      Ask FixBot
Declan Andrews
213 Reputation
2 Guides authored
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023 Member of UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G5
3 Members
72 Guides authored
9 Guide Comments
I can't find any info on suitable replacement batteries. There isn't a model number on the battery, just the following: FT804163P 2900mAh 11.02Wh BHZKF28L 3.8V. Where did you source your replacement battery from?
Trevor Graham - Reply Share
I used this one from ebay (104050, 2500mAh, the 1.25mm connector version): https://www.ebay.com/itm/115814771499 referenced by this reddit comment: https://www.reddit.com/r/techsupport/com...
I had to splice and swap the red/black wires as they were in the wrong order for the spaceview, but other than that, it fit in the monitor casing and worked as expected.
spacewarp - Reply Share
Yeah that battery worked for me. No wire swap needed: colors matched and battery works.
Joshua - Reply Share
Do you know how to open up the camera to the Eufy Spaceview Pro? The monitor works but the camera's micro usb housing got pushed inside, so the usb power cable is loose and won't stay connected to the camera. Please help! Thank you!
Lucy - Reply Share
Anyone lose their display after battery swap? Tried reseating the cable… no luck.
Past 24 Hours: 4
Past 7 Days: 62
Past 30 Days: 278
All Time: 8,840
