enTourage Pocket eDGe Motherboard Replacement
    1. enTourage Pocket eDGe Motherboard Replacement, Battery: step 1, image 1 of 3 enTourage Pocket eDGe Motherboard Replacement, Battery: step 1, image 2 of 3 enTourage Pocket eDGe Motherboard Replacement, Battery: step 1, image 3 of 3
      • Make sure the device is powered off before beginning.
      • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
      • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
      Ask FixBot
    2. enTourage Pocket eDGe Motherboard Replacement: step 2, image 1 of 1
      • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
      Ask FixBot
    3. enTourage Pocket eDGe Motherboard Replacement: step 3, image 1 of 3 enTourage Pocket eDGe Motherboard Replacement: step 3, image 2 of 3 enTourage Pocket eDGe Motherboard Replacement: step 3, image 3 of 3
      • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
      Ask FixBot
    4. enTourage Pocket eDGe Motherboard Replacement: step 4, image 1 of 1
      • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
      Ask FixBot
    5. enTourage Pocket eDGe Motherboard Replacement: step 5, image 1 of 1
      • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
      Ask FixBot
    1. enTourage Pocket eDGe Motherboard Replacement, Motherboard: step 6, image 1 of 2 enTourage Pocket eDGe Motherboard Replacement, Motherboard: step 6, image 2 of 2
      • Locate the side of the device containing the motherboard.
      • Using your J0 Phillips head screwdriver, remove the three 5mm screws from the bottom of the motherboard.
      • Using your J0 Phillips head screwdriver, remove the four 3mm screws from the top of the motherboard.
      Ask FixBot
    2. enTourage Pocket eDGe Motherboard Replacement: step 7, image 1 of 1
      • Using the plastic spudger, carefully pry the bottom of the motherboard up and away from the casing.
      Ask FixBot
    3. enTourage Pocket eDGe Motherboard Replacement: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Position your device so the inside edge of the motherboard is closest to you.
      • Locate the three wires connecting the motherboard to the rest of the device.
      • Using your finger or a pair of tweezers, gently remove each of these from the motherboard.
      Ask FixBot
    4. enTourage Pocket eDGe Motherboard Replacement: step 9, image 1 of 1
      • Lift the outer edge of the motherboard up. Carefully disconnect the 3 connections on bottom of the motherboard by pulling gently.
      Ask FixBot
    5. enTourage Pocket eDGe Motherboard Replacement: step 10, image 1 of 2 enTourage Pocket eDGe Motherboard Replacement: step 10, image 2 of 2
      • The motherboard is now connected in only one place on the edge of the device. Being careful of this, flip the motherboard outside of the device, leaving it connected to the foam padding inside of the device.
      • Carefully pry the small rectangle apart from the thin strip of foam.
      • If the foam is still intact you may leave the foam in order to reattach the new motherboard.
      Ask FixBot
Finish Line
Adrian Do
355 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 21
All Time: 911
