Up to 20% off select tools
enTourage Pocket eDGe Battery Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
111
All Time:
2,362
Comments: 2
2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Parts
Tools
Introduction
Go to step 1 ↓
The enTourage Pocket eDGe may experience battery failure. If you need to replace the battery of your enTourage Pocket eDGe for any reason, follow this guide.
    1. enTourage Pocket eDGe Battery Replacement, Battery: step 1, image 1 of 3 enTourage Pocket eDGe Battery Replacement, Battery: step 1, image 2 of 3 enTourage Pocket eDGe Battery Replacement, Battery: step 1, image 3 of 3
      • Make sure the device is powered off before beginning.
      • Open the Pocket Edge and place device with the screens face down. The side containing the stylus should be on the left.
      • Remove all eight elliptical rubber tabs covering screws using your finger or spudger.
      Ask FixBot
    2. enTourage Pocket eDGe Battery Replacement: step 2, image 1 of 1
      • Using your J1 Phillips head screwdriver, remove all eight 6mm screws from the back of your device.
      Ask FixBot
    3. enTourage Pocket eDGe Battery Replacement: step 3, image 1 of 3 enTourage Pocket eDGe Battery Replacement: step 3, image 2 of 3 enTourage Pocket eDGe Battery Replacement: step 3, image 3 of 3
      • Using the plastic opening tool, lift the back plate from both sides of your device and remove them.
      Ask FixBot
    4. enTourage Pocket eDGe Battery Replacement: step 4, image 1 of 1
      • Locate the side containing the battery. Lift the top of the battery out using your finger and the indentation at the top.
      Ask FixBot
    5. enTourage Pocket eDGe Battery Replacement: step 5, image 1 of 1
      • Carefully unplug the bottom side of the battery from the connecting plug and set the disconnected battery aside.
      Ask FixBot
3 other people completed this guide.
Author
with
Adrian Do
355 Reputation
3 Guides authored
2 Guide Comments
Great tutorial! I have two of these. Does anyone know where I can buy a replacement battery? I have looked everywhere. I would retrofit if I could find one large and flat enough. 7.2v 2000mA. Hate to have to trash them but they don’t make parts anymore.
Ron - Reply Share
does anyone know the pin out of the battery connector, thank you
Tony - Reply Share
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 111
All Time: 2,362
