Up to 20% off select tools
eMac Hard Drive Replacement
Views: 20K
View statistics:
Past 24 Hours:
9
Past 7 Days:
57
Past 30 Days:
237
All Time:
20,329
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 36
36 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes - 2 hours
Difficulty: Difficult
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
The hard drive in the eMac is pretty tough to get to, and requires disassembling most of the computer.
    1. eMac Hard Drive Replacement, Door Removal: step 1, image 1 of 3 eMac Hard Drive Replacement, Door Removal: step 1, image 2 of 3 eMac Hard Drive Replacement, Door Removal: step 1, image 3 of 3
      • It should be noted that these guides are written based on a late-model eMac (2005, 1.42GHz, DDR). They will differ slightly from the older model eMacs that use PC-133 RAM.
      • Lay the eMac screen-down on a flat surface. I've found it convenient to use a carpeted floor because the computer is so heavy.
      • Remove the single phillips #2 screw on the RAM door, and remove the door
      • The screw is captive in the door, so don't worry about losing it.
      Ask FixBot
    1. eMac Hard Drive Replacement, Bottom Screw Removal: step 2, image 1 of 1
      • Before starting this process it's important to note that the eMac can have some seriously dangerous voltages inside of it, thanks to the CRT display. Before working on an eMac, you should unplug it, press the power button to clear any stored charge on the motherboard, and then let it sit for 24-hours (or more) to allow the CRT to discharge.
      • You can read more about CRT safety procedures here. If you aren't experienced with working on devices featuring a CRT, it's recommended that you don't proceed any further.
      • On the bottom side of the eMac, remove the following screws:
      • A single 2.5mm hex screw
      • Two #2 phillips screws
      Ask FixBot
    2. eMac Hard Drive Replacement, Top and Side Screws: step 3, image 1 of 3 eMac Hard Drive Replacement, Top and Side Screws: step 3, image 2 of 3 eMac Hard Drive Replacement, Top and Side Screws: step 3, image 3 of 3
      • Remove two 2.5mm hex screws from each of the other sides of the computer.
      Ask FixBot
    3. eMac Hard Drive Replacement, Power Button Cable: step 4, image 1 of 2 eMac Hard Drive Replacement, Power Button Cable: step 4, image 2 of 2
      • Now, the shell can almost be separated from the computer.
      • There is a cable that connects to the power button. This must be disconnected before removing the housing completely.
      • Lift the housing enough to allow you to fit your hand through the access door, and disconnect the cable at the power button.
      Ask FixBot
    4. eMac Hard Drive Replacement, Shell Removal: step 5, image 1 of 1
      • Now the entire shell can be removed from the computer.
      Ask FixBot
    1. eMac Hard Drive Replacement, Panel Removal: step 6, image 1 of 3 eMac Hard Drive Replacement, Panel Removal: step 6, image 2 of 3 eMac Hard Drive Replacement, Panel Removal: step 6, image 3 of 3
      • The motherboard access panel is held on by 4 phillips #2 screws.
      • Remove the screws, then use your fingers to pull on the top tabs to separate the panel from the computer frame.
      Ask FixBot
    1. eMac Hard Drive Replacement, Cables: step 7, image 1 of 3 eMac Hard Drive Replacement, Cables: step 7, image 2 of 3 eMac Hard Drive Replacement, Cables: step 7, image 3 of 3
      • To remove the fan assembly, several cables must be disconnected first:
      • 3-pin fan cable
      • Ground wire, requires phillips #2 screwdriver
      • 2-pin AC cable to power supply
      Ask FixBot
    2. eMac Hard Drive Replacement, Screws: step 8, image 1 of 2 eMac Hard Drive Replacement, Screws: step 8, image 2 of 2
      • Now remove the following screws securing the fan assembly:
      • 3x coarse thread phillips #2
      • 1x machine thread phillips #2
      Ask FixBot
    3. eMac Hard Drive Replacement: step 9, image 1 of 1
      • There may be a zip tie holding another cable to the fan assembly, cut it to remove the fan assembly.
      Ask FixBot
    4. eMac Hard Drive Replacement, Assembly Removal: step 10, image 1 of 2 eMac Hard Drive Replacement, Assembly Removal: step 10, image 2 of 2
      • You should now be able to remove the fan assembly.
      • Doing this will expose more of the CRT neck, be careful not to touch this area because it can contain high voltages (and is fragile)
      Ask FixBot
    1. eMac Hard Drive Replacement, Bottom Connectors: step 11, image 1 of 1
      • There are four connectors at the bottom of the motherboard that must be removed.
      Ask FixBot
    2. eMac Hard Drive Replacement, Display Connector: step 12, image 1 of 3 eMac Hard Drive Replacement, Display Connector: step 12, image 2 of 3 eMac Hard Drive Replacement, Display Connector: step 12, image 3 of 3
      • There is a large display connector that must be removed. This can be done by squeezing the tabs and pulling.
      Ask FixBot
    3. eMac Hard Drive Replacement, Power Button Cable: step 13, image 1 of 1
      • The power button cable may be tucked in the casing, you will need to un-tuck it.
      Ask FixBot
    4. eMac Hard Drive Replacement, Screws: step 14, image 1 of 3 eMac Hard Drive Replacement, Screws: step 14, image 2 of 3 eMac Hard Drive Replacement, Screws: step 14, image 3 of 3
      • There are several phillips #2 screws that hold the eMac motherboard assembly to the rest of the computer. They will all need to be removed.
      • 2 large ones near the drive bay door.
      • 7 smaller ones scattered around
      Ask FixBot
    5. eMac Hard Drive Replacement, Screws (Continued): step 15, image 1 of 2 eMac Hard Drive Replacement, Screws (Continued): step 15, image 2 of 2
      • More of the screw locations from the previous step
      Ask FixBot
    6. eMac Hard Drive Replacement, Motherboard Assembly: step 16, image 1 of 1
      • The motherboard assembly should now come free.
      Ask FixBot
    1. eMac Hard Drive Replacement, Power Cable: step 17, image 1 of 2 eMac Hard Drive Replacement, Power Cable: step 17, image 2 of 2
      • Disconnect the 4-pin hard drive power connector.
      Ask FixBot
    2. eMac Hard Drive Replacement, Caddy Screws: step 18, image 1 of 1
      • The hard drive is fastened to a caddy. In order to remove it, the caddy must be removed first.
      • It is secured to the motherboard assembly with two phillips #2 screws. Remove them, but don't pull the drive out yet.
      Ask FixBot
    3. eMac Hard Drive Replacement, IDE Cable: step 19, image 1 of 2 eMac Hard Drive Replacement, IDE Cable: step 19, image 2 of 2
      • The drive is still connected with an IDE cable, which is folded under the caddy.
      • Disconnect the IDE cable from the motherboard, and lift the drive caddy out.
      Ask FixBot
    4. eMac Hard Drive Replacement, Drive Screws: step 20, image 1 of 3 eMac Hard Drive Replacement, Drive Screws: step 20, image 2 of 3 eMac Hard Drive Replacement, Drive Screws: step 20, image 3 of 3
      • The hard drive is held in the caddy with four phillips screws. Remove them.
      • Also disconnect the IDE cable from the drive. It can now be removed from the caddy.
      Ask FixBot
36 other people completed this guide.
Author
with
Chris Green
38,466 Reputation
49 Guides authored
Master Techs Member of Master Techs
Community
337 Members
8,294 Guides authored
5 Guide Comments
I love you.
Maybe I’m being premature, but this gives me hope that I might be able to release the drive that’s been trapped inside my eMac for 20 years, after which I will for sure love you. My first obstacle is stripped hex screws, but my second was not knowing what the !&&* to do if I DID manage to open it! I’m determined to find a way past those jerks and then get through the next 19 steps. Thanks in advance!
Mary Colbert - Reply Share
I'm really surprised you're not including the directions to discharge the CRT. The eMacs in particular have a hard neck to avoid touching and the risk is being hit by 25,000+ volts. We were always taught to discharge these as soon as removing the back panel.
Rebecca Winter - Reply Share
Top of step two, Rebecca.
PJ Sayegh - Reply Share
good enough to make me curious
afton HTC Kaiser - Reply Share
Thank you, thank you, thank you. My eMac never worked properly. I bought it in early 2003. Less than 2 months later it stopped being able to receive emails. It weighs as much as a Buick and I live on the 4th floor of a walk-up, so I had to just deal with its flaws. A few years later a big, strong new neighbor carried it to the Genius Bar for me. After they repaired it it worked until 2010. Then it died a slow, painful, ugly death. Apple wouldn't touch it. Neither would any of the computer repair places here in NYC. It's been sitting in my apartment for 15 years, waiting for its hard drive to be pulled. I was so happy when I found this website. I bought the hex key tool using your link. I just finished pulling the hard drive. It took about an hour and forty-five minutes because of the tight space I had to work it. But it's done. Yay!!! I'm extremely grateful for the fantastic step-by-step instructions and the photos. I definitely would not have been able to do it without ifixit.
JadeDoe - Reply Share
Past 24 Hours: 9
Past 7 Days: 57
Past 30 Days: 237
All Time: 20,329
