dreamGEAR Quad Dock Pro LEDs Replacement
    1. dreamGEAR Quad Dock Pro LEDs Replacement, Prerequisite Guide to Accessing Interior: step 1, image 1 of 2 dreamGEAR Quad Dock Pro LEDs Replacement, Prerequisite Guide to Accessing Interior: step 1, image 2 of 2
      • Remove the rubber foot pads on the bottom of the device using a plastic opening tool.
      Ask FixBot
    2. dreamGEAR Quad Dock Pro LEDs Replacement: step 2, image 1 of 2 dreamGEAR Quad Dock Pro LEDs Replacement: step 2, image 2 of 2
      • Remove the six 2 mm PH0 screws on the bottom of the device.
      • Four of those screws are located under the foot pads.
      Ask FixBot
    3. dreamGEAR Quad Dock Pro LEDs Replacement: step 3, image 1 of 1
      • Gently remove the bottom of the device.
      Ask FixBot
    1. dreamGEAR Quad Dock Pro LEDs Replacement, Mother Board: step 4, image 1 of 2 dreamGEAR Quad Dock Pro LEDs Replacement, Mother Board: step 4, image 2 of 2
      • Remove the four 1.8 mm J1 screws.
      • Remove the two 2mm PH0 screws.
      Ask FixBot
    2. dreamGEAR Quad Dock Pro LEDs Replacement: step 5, image 1 of 1
      • Gently pick up the mother board
      • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
      Ask FixBot
    3. dreamGEAR Quad Dock Pro LEDs Replacement: step 6, image 1 of 2 dreamGEAR Quad Dock Pro LEDs Replacement: step 6, image 2 of 2
      • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
      Ask FixBot
    1. dreamGEAR Quad Dock Pro LEDs Replacement, LEDs: step 7, image 1 of 2 dreamGEAR Quad Dock Pro LEDs Replacement, LEDs: step 7, image 2 of 2
      • Desolder the two points following the instructions included in your soldering kit as you remove the light.
      • FIRE HAZARD! BURN DANGER! Follow all the safety precautions included with your soldering kit.
      • You can follow iFixit's guide to soldering here.
      Ask FixBot
Jacob
757 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 512
