d.light Solar Lantern S2 Solar Panel Replacement
    1. d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: step 1, image 1 of 2 d.light Solar Lantern S2 Solar Panel Replacement, Solar Panel: step 1, image 2 of 2
      • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
      • The location of the other two screws are marked in red.
      Ask FixBot
    2. d.light Solar Lantern S2 Solar Panel Replacement: step 2, image 1 of 2 d.light Solar Lantern S2 Solar Panel Replacement: step 2, image 2 of 2
      • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
      Ask FixBot
    3. d.light Solar Lantern S2 Solar Panel Replacement: step 3, image 1 of 2 d.light Solar Lantern S2 Solar Panel Replacement: step 3, image 2 of 2
      • Desolder the yellow and black wires that connect the solar panel to the circuit board.
      • Remove the solar panel by pressing on the mounting clips (underneath fingers) using the spudger.
      Ask FixBot
    4. d.light Solar Lantern S2 Solar Panel Replacement: step 4, image 1 of 2 d.light Solar Lantern S2 Solar Panel Replacement: step 4, image 2 of 2
      • Solder the wires to the solar panel (positive to positive, negative to negative).
      Ask FixBot
2 other people completed this guide.
Jeremiah Rhoades
501 Reputation
3 Guides authored
IUPUI, Team S2-G3, Harley Fall 2017 Member of IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Members
35 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,310
