d.light Solar Lantern S2 Battery Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
32
Past 30 Days:
99
All Time:
3,742
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 3 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide shows how to replace the battery for the d.light Solar Lantern S2.
Tools
    1. d.light Solar Lantern S2 Battery Replacement, Battery: step 1, image 1 of 2 d.light Solar Lantern S2 Battery Replacement, Battery: step 1, image 2 of 2
      • To remove the lens, three T15 x 12.5mm screws must be removed by a T15 head screwdriver.
      • The location of the other two screws are marked in red.
      Ask FixBot
    2. d.light Solar Lantern S2 Battery Replacement: step 2, image 1 of 3 d.light Solar Lantern S2 Battery Replacement: step 2, image 2 of 3 d.light Solar Lantern S2 Battery Replacement: step 2, image 3 of 3
      • After the lens has been removed the back cover needs to be removed. There are no snaps or screws holding it in place.
      Ask FixBot
    3. d.light Solar Lantern S2 Battery Replacement: step 3, image 1 of 3 d.light Solar Lantern S2 Battery Replacement: step 3, image 2 of 3 d.light Solar Lantern S2 Battery Replacement: step 3, image 3 of 3
      • Take the battery out of its setting. It is only held in by friction (no snaps or screws).
      • Disconnect the battery by unpluging the white connector.
      • Install the new battery
      Ask FixBot
5 other people completed this guide.
Jeremiah Rhoades
501 Reputation
3 Guides authored
IUPUI, Team S2-G3, Harley Fall 2017 Member of IUPUI, Team S2-G3, Harley Fall 2017
IUPUI-HARLEY-F17S2G3
3 Members
36 Guides authored
1 Guide Comment
thanks for this.
You didn’t mention the model/name of the battery replacement. Can you help with that?
Albert H - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 99
All Time: 3,742
