bypass broken USB on GARMIN Gps
    1. bypass broken USB on GARMIN Gps, Fix broken Garmin charging usb port: step 1, image 1 of 1
      • steps follow below
      Ask FixBot
    2. bypass broken USB on GARMIN Gps: step 2, image 1 of 1
      • The Garmin mini usb port seems to be designed to break easily forcing you to buy a new GPS. This is how to bypass a broken usb port on the back of garmin GPS receivers. It will leave you with a GPS which works with the car adapter only.
      Ask FixBot
    3. bypass broken USB on GARMIN Gps: step 3, image 1 of 1
      • The battery must be removed for safety since the yellow wire which sends a safety signal to the charging electronics about the battery heat levels will be bypassed. We will be powering the unit directly from the Garmin Car Charger (others may not work since Garmin has special circuitry in its chargers).
      Ask FixBot
      • # using a mini torx screwdriver, remove all the screws and seperate the front and back of the case. # if the usb conector is still on the circuit board, carefully twist it off and discard # cut the car charger cable a few cm from the usb connector and strip the two wires back 0.5 cm.the middle wire is positive, the outer mesh sheath, negative.
      Ask FixBot
      • fold open the two halves carefully. Try NOT to pull out any ribbon cables. If you do pull one out, open the tiny folding clamp and carefully put it back in
      Ask FixBot
      • make the usb port hole in the back plastic larger and feed charger cable in # pull/disconnet the white battery connecter from the circuit board # pry the glued in place battery loose with a plastic (not metal) spudger, guitar pick, or similar. Remove battery.
      Ask FixBot
      • DO NOT CUT battery wires AT THE SAME TIME, they will short out and battery may explode. ONE AT A TIME, cut the battery wires at the battery leaving a few cm wires on the white connector. strip the black and red ends .5cm, leave yellow wire unstripped
      Ask FixBot
      • solder or twist the positive (inner) cable to the red wire and negative(mesh) to the black wire.insulate the connections using heat shrink tubing or electrical tape
      Ask FixBot
      • wrap the cable with a lump of tape so it can't be pulled out of the hole in the case.put case carefully back together.
      Ask FixBot
      • plug car adapter into cig. lighter and turn on GPS.you now have a working GPS again.you will need to update maps using the SD card since you cant communicate using a PC any more.
      Ask FixBot
      • == Tips == * free updated maps are available at openstreetmap.http://garmin.openstreetmap.nl/ == Warnings == * make sure you dont cut battery wires at the same time, the wire cutters will short out the battery and it may explode or catch fire. wires must be cut indicidually
      Ask FixBot
4 other people completed this guide.
doggy2
293 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,338
