Up to 20% off select tools
bObi Robotic Vacuum Screen Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
91
All Time:
673
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
Introduction
Go to step 1 ↓
The step-by-step guide for removing bObi's cover and screen. For help putting bObi back together, refer to: Closing bObi's Cover Post-Repair
    1. bObi Robotic Vacuum Screen Replacement, Top Cover: step 1, image 1 of 2 bObi Robotic Vacuum Screen Replacement, Top Cover: step 1, image 2 of 2
      • Remove bObi’s front wheel to access one of the screws holding bObi together.
      • Make sure the wheel is turned closer to bObi's front touch sensors. Use your screwdriver for leverage, and the wheel will pop up and out.
      • Uninstall the larger screw that sits deeper in the wheel compartment.
      Ask FixBot
    2. bObi Robotic Vacuum Screen Replacement: step 2, image 1 of 3 bObi Robotic Vacuum Screen Replacement: step 2, image 2 of 3 bObi Robotic Vacuum Screen Replacement: step 2, image 3 of 3
      • Remove bObi's dustbin.
      • Uninstall the 2 screws close to the bin and 2 smaller screws above her main brushes.
      Ask FixBot
    3. bObi Robotic Vacuum Screen Replacement: step 3, image 1 of 3 bObi Robotic Vacuum Screen Replacement: step 3, image 2 of 3 bObi Robotic Vacuum Screen Replacement: step 3, image 3 of 3
      • Lift the brush holder. To detach completely, unplug it from bObi.
      • Remove the two screws on the dustbin contact point holder inside bObi.
      • There are 4 screws beneath the main brushes. Uninstall these, and open bObi up to expose her main circuit board.
      Ask FixBot
    4. bObi Robotic Vacuum Screen Replacement: step 4, image 1 of 3 bObi Robotic Vacuum Screen Replacement: step 4, image 2 of 3 bObi Robotic Vacuum Screen Replacement: step 4, image 3 of 3
      • Detach the two circuit plugs connecting bObi's cover to the main board and the cover will be completely removed.
      Ask FixBot
    1. bObi Robotic Vacuum Screen Replacement, Screen: step 5, image 1 of 2 bObi Robotic Vacuum Screen Replacement, Screen: step 5, image 2 of 2
      • Remove the four screws that secure bObi's screen and lift the whole piece out.
      • Put the replacement screen in the open space.
      Ask FixBot
    2. bObi Robotic Vacuum Screen Replacement: step 6, image 1 of 2 bObi Robotic Vacuum Screen Replacement: step 6, image 2 of 2
      Ask FixBot
To reassemble your device, follow the guide for closing bObi, found here: Closing bObi's Cover Post-Repair
Author
with
Chelsea
2,278 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 91
All Time: 673
