bObi Pet Screen Replacement
  1. bObi Pet Screen  Replacement, Turn bObi Pet Off: step 1, image 1 of 3 bObi Pet Screen  Replacement, Turn bObi Pet Off: step 1, image 2 of 3 bObi Pet Screen  Replacement, Turn bObi Pet Off: step 1, image 3 of 3
    • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
    • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
  2. bObi Pet Screen  Replacement, Remove the Front Wheel: step 2, image 1 of 2 bObi Pet Screen  Replacement, Remove the Front Wheel: step 2, image 2 of 2
    • Grip the front wheel and pull straight up, using the screwdriver for leverage.
    • The wheel will pop out and you will see two screws beneath it.
    • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
    • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
  3. bObi Pet Screen  Replacement, Remove the Dustbin's Holders: step 3, image 1 of 3 bObi Pet Screen  Replacement, Remove the Dustbin's Holders: step 3, image 2 of 3 bObi Pet Screen  Replacement, Remove the Dustbin's Holders: step 3, image 3 of 3
    • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
    • Grip the brush compartment and pull down to reveal two screws on a red fastener.
    • Remove them with the screwdriver.
  4. bObi Pet Screen  Replacement, Remove the Main Brush Attachment: step 4, image 1 of 3 bObi Pet Screen  Replacement, Remove the Main Brush Attachment: step 4, image 2 of 3 bObi Pet Screen  Replacement, Remove the Main Brush Attachment: step 4, image 3 of 3
    • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
    • Remove the 4 screws located beneath the brush compartment.
  5. bObi Pet Screen  Replacement, Remove the Cover Screws: step 5, image 1 of 2 bObi Pet Screen  Replacement, Remove the Cover Screws: step 5, image 2 of 2
    • Remove the 2 screws on the dustbin’s red fastener.
    • Remove the fastener and set it aside for reassembly.
    • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
  6. bObi Pet Screen  Replacement, Detach the Cover: step 6, image 1 of 3 bObi Pet Screen  Replacement, Detach the Cover: step 6, image 2 of 3 bObi Pet Screen  Replacement, Detach the Cover: step 6, image 3 of 3
    • Lift the cover to reveal the main board underneath.
    • Remove the two circuit plugs connecting the lid to the mainboard.
    • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
  7. bObi Pet Screen  Replacement, Remove the Screen: step 7, image 1 of 3 bObi Pet Screen  Replacement, Remove the Screen: step 7, image 2 of 3 bObi Pet Screen  Replacement, Remove the Screen: step 7, image 3 of 3
    • Remove the four screws holding bObi Pet's screen.
    • Then, lift it straight up and out to make space for the replacement.
  8. bObi Pet Screen  Replacement, Place the New Screen: step 8, image 1 of 3 bObi Pet Screen  Replacement, Place the New Screen: step 8, image 2 of 3 bObi Pet Screen  Replacement, Place the New Screen: step 8, image 3 of 3
    • Lay the new screen in the open space on bObi Pet's lid.
    • Align the screw holes on the screen with the screw posts in bObi Pet and push down until it lies flat.
    • Install all four screws, and you'll be ready to close bObi Pet. See the following instructions: Assemble bObi Pet Post-Repair
To reassemble bObi Pet, see this tutorial: Assemble bObi Pet Post-Repair
Chelsea
2,278 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 193
