bObi Pet Power Switch Replacement
    1. bObi Pet Power Switch Replacement, Turn bObi Pet Off: step 1, image 1 of 3 bObi Pet Power Switch Replacement, Turn bObi Pet Off: step 1, image 2 of 3 bObi Pet Power Switch Replacement, Turn bObi Pet Off: step 1, image 3 of 3
      • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
      • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
      Ask FixBot
    2. bObi Pet Power Switch Replacement, Remove the Front Wheel: step 2, image 1 of 2 bObi Pet Power Switch Replacement, Remove the Front Wheel: step 2, image 2 of 2
      • Grip the front wheel and pull straight up, using the screwdriver for leverage.
      • The wheel will pop out and you will see two screws beneath it.
      • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
      • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
      Ask FixBot
    3. bObi Pet Power Switch Replacement, Remove the Dustbin's Holders: step 3, image 1 of 3 bObi Pet Power Switch Replacement, Remove the Dustbin's Holders: step 3, image 2 of 3 bObi Pet Power Switch Replacement, Remove the Dustbin's Holders: step 3, image 3 of 3
      • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
      • Grip the brush compartment and pull down to reveal two screws on a red fastener.
      • Remove them with the screwdriver.
      Ask FixBot
    4. bObi Pet Power Switch Replacement, Remove the Main Brush Attachment: step 4, image 1 of 3 bObi Pet Power Switch Replacement, Remove the Main Brush Attachment: step 4, image 2 of 3 bObi Pet Power Switch Replacement, Remove the Main Brush Attachment: step 4, image 3 of 3
      • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
      • Remove the 4 screws located beneath the brush compartment.
      Ask FixBot
    5. bObi Pet Power Switch Replacement, Remove the Cover Screws: step 5, image 1 of 2 bObi Pet Power Switch Replacement, Remove the Cover Screws: step 5, image 2 of 2
      • Remove the 2 screws on the dustbin’s red fastener.
      • Remove the fastener and set it aside for reassembly.
      • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
      Ask FixBot
    6. bObi Pet Power Switch Replacement, Detach the Cover: step 6, image 1 of 3 bObi Pet Power Switch Replacement, Detach the Cover: step 6, image 2 of 3 bObi Pet Power Switch Replacement, Detach the Cover: step 6, image 3 of 3
      • Lift the cover to reveal the main board underneath.
      • Remove the two circuit plugs connecting the lid to the mainboard.
      • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
      Ask FixBot
    1. bObi Pet Power Switch Replacement, Remove the Switch: step 7, image 1 of 3 bObi Pet Power Switch Replacement, Remove the Switch: step 7, image 2 of 3 bObi Pet Power Switch Replacement, Remove the Switch: step 7, image 3 of 3
      • The power switch is located on bObi Pet’s right side, behind the right wheel.
      • Press the small white tab on the circuit plug, then pull yo detach it from the mainboard.
      • Slide the switch up out of its holders.
      Ask FixBot
    2. bObi Pet Power Switch Replacement, Place a New Switch: step 8, image 1 of 3 bObi Pet Power Switch Replacement, Place a New Switch: step 8, image 2 of 3 bObi Pet Power Switch Replacement, Place a New Switch: step 8, image 3 of 3
      • Slide the replacement switch straight down into the holders on bObi Pet.
      • Attach the circuit plug to the mainboard securely, and you're ready to start closing bObi Pet.
      • See the guide for closing bObi Pet here: Assemble bObi Pet Post-Repair
      Ask FixBot
To reassemble your device, see the guide for assembling bObi Pet after any internal repair:
Chelsea
2,278 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 22
All Time: 355
