bObi Pet Bumper Replacement
    1. bObi Pet Bumper  Replacement, Turn bObi Pet Off: step 1, image 1 of 3 bObi Pet Bumper  Replacement, Turn bObi Pet Off: step 1, image 2 of 3 bObi Pet Bumper  Replacement, Turn bObi Pet Off: step 1, image 3 of 3
      • Before we get started, turn bObi Pet OFF and flip her over onto a flat surface.
      • Next, remove bObi Pet's dustbin. Grip the small tab on the back of the bin, and pull to remove.
      Ask FixBot
    2. bObi Pet Bumper  Replacement, Remove the Front Wheel: step 2, image 1 of 2 bObi Pet Bumper  Replacement, Remove the Front Wheel: step 2, image 2 of 2
      • Grip the front wheel and pull straight up, using the screwdriver for leverage.
      • The wheel will pop out and you will see two screws beneath it.
      • There is a larger screw set deeper in the wheel compartment. Use the screwdriver to remove it.
      • Remember to keep all screws and parts removed from bObi Pet safely aside during the repair. They may be needed for re-assembly.
      Ask FixBot
    3. bObi Pet Bumper  Replacement, Remove the Dustbin's Holders: step 3, image 1 of 3 bObi Pet Bumper  Replacement, Remove the Dustbin's Holders: step 3, image 2 of 3 bObi Pet Bumper  Replacement, Remove the Dustbin's Holders: step 3, image 3 of 3
      • Remove the screws on both sides of bObi Pet’s dustbin. Then, remove the corner pieces that were held down by the screws.
      • Grip the brush compartment and pull down to reveal two screws on a red fastener.
      • Remove them with the screwdriver.
      Ask FixBot
    4. bObi Pet Bumper  Replacement, Remove the Main Brush Attachment: step 4, image 1 of 3 bObi Pet Bumper  Replacement, Remove the Main Brush Attachment: step 4, image 2 of 3 bObi Pet Bumper  Replacement, Remove the Main Brush Attachment: step 4, image 3 of 3
      • Pull the brush compartment up until the fastener is freed from bObi Pet. Then, detach the brush compartment's circuit plug and set it aside.
      • Remove the 4 screws located beneath the brush compartment.
      Ask FixBot
    5. bObi Pet Bumper  Replacement, Remove the Cover Screws: step 5, image 1 of 2 bObi Pet Bumper  Replacement, Remove the Cover Screws: step 5, image 2 of 2
      • Remove the 2 screws on the dustbin’s red fastener.
      • Remove the fastener and set it aside for reassembly.
      • The cover is no longer secured, so carefully flip bObi Pet onto her wheels.
      Ask FixBot
    6. bObi Pet Bumper  Replacement, Detach the Cover: step 6, image 1 of 3 bObi Pet Bumper  Replacement, Detach the Cover: step 6, image 2 of 3 bObi Pet Bumper  Replacement, Detach the Cover: step 6, image 3 of 3
      • Lift the cover to reveal the main board underneath.
      • Remove the two circuit plugs connecting the lid to the mainboard.
      • bObi Pet's cover is entirely separated, and you may now access any of her internal parts for replacement.
      Ask FixBot
    1. bObi Pet Bumper  Replacement, Remove the Circuit Plugs: step 7, image 1 of 2 bObi Pet Bumper  Replacement, Remove the Circuit Plugs: step 7, image 2 of 2
      • Flip bObi Pet’s cover over onto a flat surface so that you see 2 green circuit boards positioned at the top.
      • There are 8 circuit plugs that you will need to remove. Leave the smallest circuit plug at the top in place, and do not remove it.
      • If there is any glue holding down the other wires, you may scrape it off using a tool such as a screwdriver.
      Ask FixBot
    2. bObi Pet Bumper  Replacement, Remove the Wire's Hook: step 8, image 1 of 2 bObi Pet Bumper  Replacement, Remove the Wire's Hook: step 8, image 2 of 2
      • Remove the hook holding the yellow circuit plug against the lid. Keep the small hook and all screws safely aside for later reassembly.
      • Depending on your model, bObi Pet may have one of two hooks holding the yellow wire. In this case, remove and keep both aside for reassembly.
      Ask FixBot
    3. bObi Pet Bumper  Replacement, Uninstall the Bumper Screw: step 9, image 1 of 3 bObi Pet Bumper  Replacement, Uninstall the Bumper Screw: step 9, image 2 of 3 bObi Pet Bumper  Replacement, Uninstall the Bumper Screw: step 9, image 3 of 3
      • Next, remove the 4 screws connecting the bumper to bObi Pet’s lid.
      • You may nudge two of the oblong wall sensors out of their spot on bObi Pet to make room for your screwdriver. Be sure to replace them when done.
      Ask FixBot
    4. bObi Pet Bumper  Replacement, Lift the Bumper Out: step 10, image 1 of 3 bObi Pet Bumper  Replacement, Lift the Bumper Out: step 10, image 2 of 3 bObi Pet Bumper  Replacement, Lift the Bumper Out: step 10, image 3 of 3
      • On the left and right sides of the bumper are bObi Pet’s sensor strips. They connect to the circuit board by red and white wires.
      • The sensor strips may be glued to the inside of the cover. Use a tool like a screwdriver to break off the glue.
      • Then, lift the whole bumper up and out.
      Ask FixBot
    5. bObi Pet Bumper  Replacement, Place the New Bumper: step 11, image 1 of 3 bObi Pet Bumper  Replacement, Place the New Bumper: step 11, image 2 of 3 bObi Pet Bumper  Replacement, Place the New Bumper: step 11, image 3 of 3
      • Now line up bObi Pet’s new bumper with the corresponding screw posts on her lid.
      • Make sure the sensor strips slide in behind the screw posts on both ends of the bumper.
      Ask FixBot
    6. bObi Pet Bumper  Replacement, Secure the New Bumper: step 12, image 1 of 3 bObi Pet Bumper  Replacement, Secure the New Bumper: step 12, image 2 of 3 bObi Pet Bumper  Replacement, Secure the New Bumper: step 12, image 3 of 3
      • Once the bumper is positioned securely on the lid, reinstall the 4 screws around the inside of the bumper.
      • Once again, you may nudge 2 of the oblong wall sensors out to allow room for your screwdriver and then replace them when done.
      Ask FixBot
    7. bObi Pet Bumper  Replacement, Secure the Wires: step 13, image 1 of 2 bObi Pet Bumper  Replacement, Secure the Wires: step 13, image 2 of 2
      • Next, you’ll need to replace the plastic hook removed previously. Place the yellow wire through it, and line the hook up with the screw post on the cover.
      • When aligned, install the screw on the hook.
      • Then, attach the thick yellow wire to the lower edge of the circuit board.
      Ask FixBot
    8. bObi Pet Bumper  Replacement, Start Connecting All Circuit Plugs: step 14, image 1 of 2 bObi Pet Bumper  Replacement, Start Connecting All Circuit Plugs: step 14, image 2 of 2
      • Continue reconnecting all circuit plugs.
      • In the middle of bObi Pet’s bumper is a circuit plug for one of the 5 wall sensors. Plug this one in at the topmost spot.
      Ask FixBot
    9. bObi Pet Bumper  Replacement, Finish Connecting All Circuit Plugs: step 15, image 1 of 3 bObi Pet Bumper  Replacement, Finish Connecting All Circuit Plugs: step 15, image 2 of 3 bObi Pet Bumper  Replacement, Finish Connecting All Circuit Plugs: step 15, image 3 of 3
      • The rows on each side of the cover circuit board follow the same pattern for installation.
      • The left side of the circuit board has 3 spaces: The top space corresponds to the wall sensor with the shortest wire and no tab on the circuit plug.
      • Just below that is where the leftmost wall sensor plugs in. It has a longer wire and a small white tab on its circuit plug.
      • The space on the very bottom is for bObi Pet’s sensor strips. They have red and white wires.
      Ask FixBot
    10. bObi Pet Bumper  Replacement, Double Check Wires and Connections: step 16, image 1 of 3 bObi Pet Bumper  Replacement, Double Check Wires and Connections: step 16, image 2 of 3 bObi Pet Bumper  Replacement, Double Check Wires and Connections: step 16, image 3 of 3
      • Repeat the previous process for the circuit plugs on the right and double check that all connections are secure.
      • Make sure the the red and white wires are tucked behind the screw posts at the ends of the bumper.
      • Make sure all the wires are tucked behind the black hooks lining the inside of the bumper before closing bObi Pet.
      • For assistance on reassembly, see: Assemble bObi Pet Post-Repair
      Ask FixBot
To reassemble your device, follow the guide for closing bObi Pet: Assemble bObi Pet Post-Repair
Chelsea
2,278 Reputation
31 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 379
