Up to 20% off select tools
Zune Flash 2nd Generation Center Frame Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
81
All Time:
3,628
Comments: 2
2 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 45 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
How to remove the center frame from the Zune Flash 2nd Generation.
    1. Zune Flash 2nd Generation Center Frame Replacement, Back Cover: step 1, image 1 of 2 Zune Flash 2nd Generation Center Frame Replacement, Back Cover: step 1, image 2 of 2
      • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
      • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
      • PICS MAKE NO SENSE.
      Ask FixBot
    2. Zune Flash 2nd Generation Center Frame Replacement: step 2, image 1 of 2 Zune Flash 2nd Generation Center Frame Replacement: step 2, image 2 of 2
      • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
      • You should hear a 'click' as the clip detaches from the device.
      Ask FixBot
    3. Zune Flash 2nd Generation Center Frame Replacement: step 3, image 1 of 1
      • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
      Ask FixBot
    4. Zune Flash 2nd Generation Center Frame Replacement: step 4, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 4, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 4, image 3 of 3
      • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
      Ask FixBot
    5. Zune Flash 2nd Generation Center Frame Replacement: step 5, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 5, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 5, image 3 of 3
      • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
      Ask FixBot
    1. Zune Flash 2nd Generation Center Frame Replacement, Face Plate: step 6, image 1 of 2 Zune Flash 2nd Generation Center Frame Replacement, Face Plate: step 6, image 2 of 2
      • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a Y00 Tri-Wing screwdriver.
      • Be sure to put this set of screws aside since they are a different size than any other screws in the device.
      Ask FixBot
    2. Zune Flash 2nd Generation Center Frame Replacement: step 7, image 1 of 2 Zune Flash 2nd Generation Center Frame Replacement: step 7, image 2 of 2
      • Use your finger or a Zune opening tool to pry back the two clear flaps.
      • Next lift the communications board that was being held down by the clear flaps.
      • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
      Ask FixBot
    3. Zune Flash 2nd Generation Center Frame Replacement: step 8, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 8, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 8, image 3 of 3
      • Disconnect the ribbon with the plastic opening tool by flipping up the black plastic flap where the ribbon connects to the memory board.
      • Carefully pull the ribbon out of the memory board, ensuring that the black plastic flap is up before removal to avoid the ripping the ribbon.
      Ask FixBot
    4. Zune Flash 2nd Generation Center Frame Replacement: step 9, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 9, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 9, image 3 of 3
      • Remove the battery by prying the battery off from the bottom with a Zune opening tool.
      • There is an adhesive between the battery and the device, therefore use a metal spudger to finish detaching the battery.
      • Be sure not to puncture the battery in any way when using the metal spudger.
      Ask FixBot
    5. Zune Flash 2nd Generation Center Frame Replacement: step 10, image 1 of 2 Zune Flash 2nd Generation Center Frame Replacement: step 10, image 2 of 2
      • Remove the single screw under the battery using a small Tri-Wing screwdriver.
      Ask FixBot
    6. Zune Flash 2nd Generation Center Frame Replacement: step 11, image 1 of 1
      • Disconnect the faceplate from the device by depressing the two tabs located near the middle of each of the sides using a metal spudger.
      • This will disconnect the last circuit board in the device from the center frame.
      Ask FixBot
    7. Zune Flash 2nd Generation Center Frame Replacement: step 12, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 12, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 12, image 3 of 3
      • Remove the faceplate by using a metal spudger to separate it from the remaining components.
      Ask FixBot
    1. Zune Flash 2nd Generation Center Frame Replacement, LCD Display: step 13, image 1 of 1
      • Release the LCD connector ribbon by flipping up the black switch. This will disconnect the LCD from the device.
      • At this point the LCD screen should be easily separable from the device.
      Ask FixBot
    2. Zune Flash 2nd Generation Center Frame Replacement: step 14, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 14, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement: step 14, image 3 of 3
      • The LCD ribbon is adhered to the memory board with a strip of glue.
      • It's safest to flip the display over before removing the ribbon, as shown in the first image.
      • To avoid damage, remove the LCD by pulling slowly and carefully on the ribbon, directly away from the memory board.
      Ask FixBot
    1. Zune Flash 2nd Generation Center Frame Replacement, Center Frame: step 15, image 1 of 3 Zune Flash 2nd Generation Center Frame Replacement, Center Frame: step 15, image 2 of 3 Zune Flash 2nd Generation Center Frame Replacement, Center Frame: step 15, image 3 of 3
      • Pry up the memory board from center piece with a Zune opening tool and gently pull it off.
      Ask FixBot
Author
with
killdashnine
100 Reputation
3 Guides authored
Cal Poly, Team 9-20, Regan Fall 2009 Member of Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 81
All Time: 3,628
