Up to 20% off select tools
Zune Flash 2nd Generation Back Cover Replacement
Views: 4.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
89
All Time:
4,548
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Tools
Introduction
Go to step 1 ↓
This is a guide to replacing the Back Cover on the Zune Flash 2nd Generation.
    1. Zune Flash 2nd Generation Back Cover Replacement, Back Cover: step 1, image 1 of 2 Zune Flash 2nd Generation Back Cover Replacement, Back Cover: step 1, image 2 of 2
      • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
      • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
      • PICS MAKE NO SENSE.
      Ask FixBot
    2. Zune Flash 2nd Generation Back Cover Replacement: step 2, image 1 of 2 Zune Flash 2nd Generation Back Cover Replacement: step 2, image 2 of 2
      • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
      • You should hear a 'click' as the clip detaches from the device.
      Ask FixBot
    3. Zune Flash 2nd Generation Back Cover Replacement: step 3, image 1 of 1
      • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
      Ask FixBot
    4. Zune Flash 2nd Generation Back Cover Replacement: step 4, image 1 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 4, image 2 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 4, image 3 of 3
      • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
      Ask FixBot
    5. Zune Flash 2nd Generation Back Cover Replacement: step 5, image 1 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 5, image 2 of 3 Zune Flash 2nd Generation Back Cover Replacement: step 5, image 3 of 3
      • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
      Ask FixBot
Author
with
ybahman
139 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2009 Member of Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 89
All Time: 4,548
