Introduction
This guide is an extension of the volume slider replacement guide. It will show you the steps to get to and replace the speaker at the base of the main chassis of your Zoomer Show Pony. You will need this guide if the Pony's sound is too low or distorted and can not be fixed by adjusting the volume slider.
Flip the pony over.
Remove the five Triangle 3 screws from underneath.
Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
