Zoomer Meowzies Wheels Replacement
  1. Zoomer Meowzies Wheels Replacement, Legs: step 1, image 1 of 3 Zoomer Meowzies Wheels Replacement, Legs: step 1, image 2 of 3 Zoomer Meowzies Wheels Replacement, Legs: step 1, image 3 of 3
    • Using the Triangle driver remove the four 7.5 mm screws.
    • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
    Ask FixBot
  2. Zoomer Meowzies Wheels Replacement: step 2, image 1 of 2 Zoomer Meowzies Wheels Replacement: step 2, image 2 of 2
    • Turn the device so that the the device is on its side.
    • Hold the back and belly on the device and gently pull apart.
    • Pulling with too much force might damage a few cables inside, so caution is needed.
    Ask FixBot
  3. Zoomer Meowzies Wheels Replacement: step 3, image 1 of 3 Zoomer Meowzies Wheels Replacement: step 3, image 2 of 3 Zoomer Meowzies Wheels Replacement: step 3, image 3 of 3
    • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
    Ask FixBot
  4. Zoomer Meowzies Wheels Replacement, Wheels: step 4, image 1 of 1
    • Turn the Zoomer Meowzies leg to its side.
    • Using the Triangle driver remove the two bottom 7 mm screws.
    Ask FixBot
  5. Zoomer Meowzies Wheels Replacement: step 5, image 1 of 1
    • Hold both sides of the leg and gently pull apart.
    • If pulled apart too forcefully the rest of the leg may sustain damage. Caution is advised.
    Ask FixBot
  6. Zoomer Meowzies Wheels Replacement: step 6, image 1 of 2 Zoomer Meowzies Wheels Replacement: step 6, image 2 of 2
    • Wheel should now be exposed. Pull wheel up and away from the rest of the leg to remove. Replace with new wheel if necessary.
    Ask FixBot
Muataz Alahmadi
193 Reputation
2 Guides authored
USF Tampa, Team S6-G2, Eyestone Spring 2018 Member of USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Members
16 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 44
All Time: 663
