Zoomer Meowzies Legs Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
68
All Time:
696
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This is a guide to replace the legs of the Zoomer Meowzies. Removing the legs is a prerequisite to the replacment guides for the Infrared Sensors, LED Screen “Eyes,” and the Speaker.
Tools
    1. Zoomer Meowzies  Legs Replacement, Legs: step 1, image 1 of 3 Zoomer Meowzies  Legs Replacement, Legs: step 1, image 2 of 3 Zoomer Meowzies  Legs Replacement, Legs: step 1, image 3 of 3
      • Using the Triangle driver remove the four 7.5 mm screws.
      • The two front screws are deeper than the two on the back legs which may cause difficulties. These can be reached by putting the bit in first then carefully putting the driver on slightly (not all the way)
      Ask FixBot
    2. Zoomer Meowzies  Legs Replacement: step 2, image 1 of 2 Zoomer Meowzies  Legs Replacement: step 2, image 2 of 2
      • Turn the device so that the the device is on its side.
      • Hold the back and belly on the device and gently pull apart.
      • Pulling with too much force might damage a few cables inside, so caution is needed.
      Ask FixBot
    3. Zoomer Meowzies  Legs Replacement: step 3, image 1 of 3 Zoomer Meowzies  Legs Replacement: step 3, image 2 of 3 Zoomer Meowzies  Legs Replacement: step 3, image 3 of 3
      • With insides exposed, grab leg and gently pull up and away from the body to detach them. Repeat for all legs needed.
      Ask FixBot
Muataz Alahmadi
193 Reputation
2 Guides authored
USF Tampa, Team S6-G2, Eyestone Spring 2018 Member of USF Tampa, Team S6-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S6G2
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 68
All Time: 696
