Zoomer Dino Boomer Back Button Replacement
    1. Zoomer Dino Boomer Back Button Replacement, Back Cover: step 1, image 1 of 1
      • Power off Zoomer Dino Boomer before disassembly.
      • Remove the eight 9.3mm Phillips #1 screws.
      Ask FixBot
    2. Zoomer Dino Boomer Back Button Replacement: step 2, image 1 of 2 Zoomer Dino Boomer Back Button Replacement: step 2, image 2 of 2
      • Turn dinosaur over and hold upright.
      • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
      • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
      Ask FixBot
    3. Zoomer Dino Boomer Back Button Replacement: step 3, image 1 of 3 Zoomer Dino Boomer Back Button Replacement: step 3, image 2 of 3 Zoomer Dino Boomer Back Button Replacement: step 3, image 3 of 3
      Tool used on this step:
      Buy
      • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
      • Remove back cover.
      • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
      • Do not damage the wires or circuit board.
      Ask FixBot
    1. Zoomer Dino Boomer Back Button Replacement, Back Button: step 4, image 1 of 1
      • Where the button is largest, squeeze the two white tabs together.
      Ask FixBot
    2. Zoomer Dino Boomer Back Button Replacement: step 5, image 1 of 1
      • Push in the white circular piece between these tabs as far as it will go.
      Ask FixBot
    3. Zoomer Dino Boomer Back Button Replacement: step 6, image 1 of 2 Zoomer Dino Boomer Back Button Replacement: step 6, image 2 of 2
      • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
      • Remove the back button.
      Ask FixBot
Lauren Mannix
398 Reputation
3 Guides authored
USF Tampa, Team 16-1, Wollert Fall 2015 Member of USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 2,589
