Zoom H1 Handy Recorder USB Port Replacement
Views: 6.7K
View statistics:
Past 24 Hours:
8
Past 7 Days:
37
Past 30 Days:
128
All Time:
6,690
Comments: 3
3 guide comments.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 seconds
Difficulty: Difficult
Introduction
Go to step 1 ↓
Welcome to the Zoom H1 Handy Recorder guide to replace the USB port. It will happen at times that the USB port corrodes, suffers damage, or ages in quality, making the recorder not read devices properly or not connect at all. This guide will provide step-by-step instructions to help you replace the USB port. Although this guide is easy to follow, there is a special skill necessary: soldering.
Caution! About soldering: there are some hazards to be aware of, necessary equipment, and the act of soldering itself. Luckily, iFixit has a Wiki on all of the above! Click here to access the Wiki. Now go and make your Zoom H1 Handy Recorder work like new again!
Tools
    1. Zoom H1 Handy Recorder USB Port Replacement, USB Port: step 1, image 1 of 1
      • Turn the device over with its display down.
      Ask FixBot
    2. Zoom H1 Handy Recorder USB Port Replacement: step 2, image 1 of 1
      • Remove the battery cover, pressing down on the tabs and sliding.
      Ask FixBot
    3. Zoom H1 Handy Recorder USB Port Replacement: step 3, image 1 of 1
      • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
      Ask FixBot
    4. Zoom H1 Handy Recorder USB Port Replacement: step 4, image 1 of 1
      • Carefully pry up the top end of the back cover using one finger.
      Ask FixBot
    5. Zoom H1 Handy Recorder USB Port Replacement: step 5, image 1 of 1
      • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
      Ask FixBot
    6. Zoom H1 Handy Recorder USB Port Replacement: step 6, image 1 of 1
      • Unscrew the circuit board screw.
      • This screw is located down near the bottom of the device on the blue circuit board. It is just to the right of the USB port.
      Ask FixBot
    7. Zoom H1 Handy Recorder USB Port Replacement: step 7, image 1 of 1
      • Use a plastic removal tool to disconnect the blue circuit board from the green circuit board underneath.
      Ask FixBot
    8. Zoom H1 Handy Recorder USB Port Replacement: step 8, image 1 of 1
      • Turn the circuit board on its side to reveal the USB soldering points.
      Ask FixBot
    9. Zoom H1 Handy Recorder USB Port Replacement: step 9, image 1 of 1
      • De-solder the USB port from its four soldering points.
      • Be careful not to damage the wire connected to the USB port during de-soldering.
      Ask FixBot
    10. Zoom H1 Handy Recorder USB Port Replacement: step 10, image 1 of 1
      • Place the new USB port in the same spot on the board, and re-solder at each of the four points.
      • Ensure you re-solder the wire into the same connection you removed it from during desoldering
      Ask FixBot
    11. Zoom H1 Handy Recorder USB Port Replacement: step 11, image 1 of 1
      • Rotate the circuit board back to its initial position, with the port on the underside of the board.
      Ask FixBot
    12. Zoom H1 Handy Recorder USB Port Replacement: step 12, image 1 of 1
      • Replace the circuit board screw.
      Ask FixBot
2 other people completed this guide.
Alex
809 Reputation
5 Guides authored
3 Guide Comments
the third screw is on the outside of the case, the same place
xhbang - Reply Share
This is awesome. Do you know if I can switch the port for USB-C?
Regan Ryan - Reply Share
What USB Port do i need to get?
Ricky Smith - Reply Share
Past 24 Hours: 8
Past 7 Days: 37
Past 30 Days: 128
All Time: 6,690
