Zoom H1 Handy Recorder Speaker Replacement
    1. Zoom H1 Handy Recorder Speaker Replacement, Speaker: step 1, image 1 of 1
      • Turn the device over with its display down.
      Ask FixBot
    2. Zoom H1 Handy Recorder Speaker Replacement: step 2, image 1 of 1
      • Remove the battery cover, pressing down on the tabs and sliding.
      Ask FixBot
    3. Zoom H1 Handy Recorder Speaker Replacement: step 3, image 1 of 1
      • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover.
      Ask FixBot
    4. Zoom H1 Handy Recorder Speaker Replacement: step 4, image 1 of 1
      • Carefully pry up the top end of the back cover using one finger.
      Ask FixBot
    5. Zoom H1 Handy Recorder Speaker Replacement: step 5, image 1 of 1
      • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
      Ask FixBot
    6. Zoom H1 Handy Recorder Speaker Replacement: step 6, image 1 of 1
      • De-solder the white and black speaker wires from their soldering points.
      • Speaker soldering points are located on the thin section of the blue circuit board, and are marked with “SP+” and “SP-”.
      • Keep in mind which color wire was connected at which terminal.
      Ask FixBot
    7. Zoom H1 Handy Recorder Speaker Replacement: step 7, image 1 of 1
      • Remove the damaged speaker from its place at the very bottom of the case, just below the battery input.
      • You will have to break the glue holding the speaker in place before removing it.
      Ask FixBot
    8. Zoom H1 Handy Recorder Speaker Replacement: step 8, image 1 of 1
      • Replace the damaged speaker and re-solder to the original solder points.
      • Ensure that the negative wire is soldered to the “SP-” while the positive wire is soldered to the “SP+” point.
      Ask FixBot
Alex
809 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 46
All Time: 2,236
