Zoom H1 Handy Recorder Battery Terminal Replacement
Views: 7.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
28
Past 30 Days:
110
All Time:
7,764
Comments: 9
2 comments on steps, 7 guide comments.
Go to guide comments
Completed: 0
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 45 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
Welcome to the Zoom H1 Handy Recorder guide to replace the battery terminal. It will happen at times that the battery terminal corrodes, suffers damage, or ages in quality, making the device not work properly or cease to turn on in general. This guide will provide step-by-step instructions to help you replace the battery terminal. Although this guide is easy to follow, there is a special skill necessary: soldering.
Caution! About soldering: there are some hazards to be aware of, necessary equipment, and the act of soldering itself. Luckily, iFixit has a Wiki on all of the above! Click here to access the Wiki. Now go and make your Zoom H1 Handy Recorder work like new again!
Tools
    1. Zoom H1 Handy Recorder Battery Terminal Replacement, Battery Terminal: step 1, image 1 of 1
      • Place the device so the display is down.
      Ask FixBot
    2. Zoom H1 Handy Recorder Battery Terminal Replacement: step 2, image 1 of 1
      • Remove the battery cover, pressing down on the tabs and sliding.
      Ask FixBot
    3. Zoom H1 Handy Recorder Battery Terminal Replacement: step 3, image 1 of 1
      • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
      Ask FixBot
    4. Zoom H1 Handy Recorder Battery Terminal Replacement: step 4, image 1 of 1
      • Carefully pry up the top end of the back cover using one finger
      Ask FixBot
    5. Zoom H1 Handy Recorder Battery Terminal Replacement: step 5, image 1 of 1
      • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
      Ask FixBot
    6. Zoom H1 Handy Recorder Battery Terminal Replacement: step 6, image 1 of 1
      • De-solder at terminal point one.
      Ask FixBot
    7. Zoom H1 Handy Recorder Battery Terminal Replacement: step 7, image 1 of 1
      • De-solder at the second terminal point.
      Ask FixBot
    8. Zoom H1 Handy Recorder Battery Terminal Replacement: step 8, image 1 of 2 Zoom H1 Handy Recorder Battery Terminal Replacement: step 8, image 2 of 2
      • Remove the faulty terminals
      Ask FixBot
    9. Zoom H1 Handy Recorder Battery Terminal Replacement: step 9, image 1 of 1
      • Place new lead in at point one and re-solder at the point.
      Ask FixBot
    10. Zoom H1 Handy Recorder Battery Terminal Replacement: step 10, image 1 of 1
      • Place second lead at point 2 and re-solder.
      Ask FixBot
To Re-construct device, perform these steps in reverse order.
Alex
809 Reputation
5 Guides authored
7 Guide Comments
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Reply Share
Mine has third screw under the serial-number sticker.
halluciana - Reply Share
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Reply Share
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Reply Share
Same problem, without any reason it is dead
eevilcute - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 110
All Time: 7,764
