Up to 20% off select tools
Zoll AED Plus Battery Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
3
All Time:
30
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 seconds - 5 minutes
Difficulty: Easy
Medical Equipment
Neither iFixit nor this repair guide is endorsed by or affiliated with the medical device manufacturer.
Community-Contributed Guide
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
Here's how to replace the batteries on your ZOLL AED Plus!
      • Open the Battery Cover: Turn the AED face down. Insert a coin or tool into the two slots at the bottom of the back cover to release the locking latches, then lift the cover off.
      Ask FixBot
      • Remove Old Batteries: Take out all 10 old batteries at once and discard them properly. Never mix old and new batteries.
      Ask FixBot
      • Insert New Batteries: Place the new batteries into the well, paying heed to the positive and negaive ends.
      Ask FixBot
      • Press the Reset Button: Once the final central batteries are in, the unit will power on and prompt “If new batteries press button”. Press and hold the small blue or green reset button located above the center batteries within 15 seconds to reset the internal power gauge.
      Ask FixBot
      • Secure the Cover: Slide the battery compartment cover back into its grooves and press down until it snaps firmly into place.
      Ask FixBot
      • Verify Status: Flip the unit right-side up and check the status indicator window on the front. Confirm that a green check mark appears and the unit is not beeping. If it is, check the pads, and if they are ok, your AED may need authorised service.
      Ask FixBot
Finish Line
Lukas Pan
5 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 30
