Up to 20% off select tools
Zoe outside temperature sensor Replacement
View statistics:
Past 24 Hours:
8
Past 7 Days:
64
Past 30 Days:
242
All Time:
801
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Difficult
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
Renault Zoe no heat
Car shows double dashes '--' instead of outside temperature.
Heat pump not running. No heat only fan.
Solved by replacing outside temperature sensor.
Background info
When this happens, the climate control does not activate, and the air source heat pump (AC compressor) does not start, leaving the Zoe without heating.
I took the car to a Renault workshop. They said that the issue was caused by humidity in the cables, and wanted approximately 1000 euro to replace the sensor and cables.
My car is usually parked outdoors and this problem started during fall when it was wet.
Leaving the car in a warm garage for a few days resolved the issue, so it seems like a humidity problem.
After some reading online this seems to be a fairly common issue with similar Renault cars (Clio and others).
I ordered a sensor from Amazon, although it was not specified as for Zoe.
https://www.amazon.se/dp/B0D2KL46L6
Rated Difficult due to soldering.
    1. Zoe outside temperature sensor Replacement, Outside temperature sensor: step 1, image 1 of 1
      • Adjust mirror max left and down to create a gap at the top
      • Carefully pry out the mirror with a screwdriver near the round center
      • Disconnect mirror heating cable
      • Push on the plastic latch, circled in red, to release the bottom part where the sensor is mounted
      Ask FixBot
    2. Zoe outside temperature sensor Replacement: step 2, image 1 of 1
      • New sensor soldered in place.
      • The sensor is just pushed in place, easily removed. Harder to re-install.
      Ask FixBot
    3. Zoe outside temperature sensor Replacement: step 3, image 1 of 1
      • Old sensor characteristics, approximate numbers
      • 3.1 k Ohm @ 20 C (68 F)
      • 9 k Ohm @ 1 C (35 F)
      Ask FixBot
Author
with
Hans Persson
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 64
Past 30 Days: 242
All Time: 801
