Up to 20% off select tools
Zipper Pull Replacement
Views: 41K
View statistics:
Past 24 Hours:
34
Past 7 Days:
247
Past 30 Days:
1,112
All Time:
40,700
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 7
7 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Very easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Patagonia
Patagonia and iFixit are celebrating the stories we wear by collaborating to provide guides for Patagonia's most popular apparel repairs.
Tools
Introduction
Go to step 1 ↓
A zipper pull is a piece of cording or ribbon that attaches to a zipper slider to make it easier to grab on to - especially while wearing mittens or gloves!
This guide will demonstrate how to attach a new pull when it has gone missing or become damaged.
Read through the entire guide before starting the repair, and gather the necessary tools and materials. While Patagonia-specific materials are ideal, they are not required. Patagonia replacement parts can be obtained by calling or messaging Patagonia Customer Service.
Alternatively, Patagonia products can be taken to a local retail store for repair evaluation or sent in to Patagonia through their mail-in repair service.
Let's get fixing!
WARNING! Small Parts. Patagonia does not recommend conducting these repairs on garments intended for children age 2 or under. Instead, we recommend return of the product for professional repair services.
Return to the Patagonia Care & Repair homepage.
Video Overview
Zipper pull replacement overview.
    1. Zipper Pull Replacement, Locate the zipper tab: step 1, image 1 of 3 Zipper Pull Replacement, Locate the zipper tab: step 1, image 2 of 3 Zipper Pull Replacement, Locate the zipper tab: step 1, image 3 of 3
      • This tutorial demonstrates how to insert a paracord pull with a rubber end, a common type of zipper pull on Patagonia products. These pulls come in a large size for main zippers and a small size for pockets (reference image #2).
      • If you need to remove a damaged zipper pull, skip to Step 6.
      • Locate the zipper slider that is missing a pull. The slider has a tab with two holes, one where the tab is attached to the slider body and one at the end of the tab.
      Ask FixBot
    2. Zipper Pull Replacement, Insert the paracord end: step 2, image 1 of 2 Zipper Pull Replacement, Insert the paracord end: step 2, image 2 of 2
      • Pinch the paracord end of the pull and slide it into the tab hole that's closer to the slider.
      • It doesn't matter whether it's inserted from the top or bottom.
      • Pull the paracord through the tab hole.
      • Use pliers to help pinch the paracord and aid in this step, especially if the tab hole is small.
      Ask FixBot
    3. Zipper Pull Replacement, Thread the pull through the second hole: step 3, image 1 of 2 Zipper Pull Replacement, Thread the pull through the second hole: step 3, image 2 of 2
      • Pinch the paracord end of the pull and thread it through the other hole on the slider tab, the one furthest from the slider body.
      • Now there will be a paracord loop emerging from this tab hole (reference red arrow, image #2).
      Ask FixBot
    4. Zipper Pull Replacement, Loop the rubber end: step 4, image 1 of 2 Zipper Pull Replacement, Loop the rubber end: step 4, image 2 of 2
      • Thread the rubber end of the paracord pull through the loop emerging from the slider tab.
      Ask FixBot
    5. Zipper Pull Replacement, Tighten the pull: step 5, image 1 of 2 Zipper Pull Replacement, Tighten the pull: step 5, image 2 of 2
      • While holding the slider, pull the rubber end of the zipper pull to tighten it. The zipper pull is now inserted and should lay flat on the slider tab.
      Ask FixBot
      • To take off a damaged zipper pull, do these same steps in reverse.
      • Pliers can be helpful in getting into the small space and loosening the tension of the pull.
      • Discard the damaged pull responsibly.
      Ask FixBot
Finish Line
6 other people completed this guide.
Author
with
Brittany McCrigler
91,191 Reputation
142 Guides authored
1 Guide Comment
Awesome! Thanks for the training!
Kathleen Hutton - Reply Share
Past 24 Hours: 34
Past 7 Days: 247
Past 30 Days: 1,112
All Time: 40,700
